[postgis-users] problem enabling GEOS support on freebsd 4
theo burry
tvburry at yahoo.com
Tue Oct 17 12:34:32 PDT 2006
I am working with postgis on freebsd 4, postgres 7.4.
I'd like to be able to use some of the functions that require GEOS. I installed postgis-1.1.3 from the freebsd ports using pkg_add. For certain functions I get the error
ERROR: boundary:: operation not implemented - compile PostGIS with JTS or GEOS support
When I try to build postgis-1.1.5 from source, I get the following error:
gcc -DUSE_VERSION=74 -DPOSTGIS_LIB_VERSION='"1.1.5"' -DPOSTGIS_VERSION='"1.1 USE_GEOS=1 USE_PROJ=1 USE_STATS=1"' -DPOSTGIS_SCRIPTS_VERSION='"1.1.5"' -DPOSTGIS_BUILD_DATE='"2006-10-17 19:18:24"' -I/usr/local/include -DUSE_PROJ -I/usr/local/include/postgresql/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -Wall -g -O2 -fPIC -fexceptions -DUSE_GEOS -I/usr/local/include -c -o lwgeom_gist.o lwgeom_gist.c
lwgeom_gist.c:552: macro `gistentryinit' used with too many (8) args
lwgeom_gist.c:552: warning: preprocessing directive not recognized within macro arg
lwgeom_gist.c:562: macro `gistentryinit' used with only 6 args
lwgeom_gist.c:562: warning: preprocessing directive not recognized within macro arg
lwgeom_gist.c:563: `#else' not within a conditional
lwgeom_gist.c:565: unbalanced `#endif'
gmake[1]: *** [lwgeom_gist.o] Error 1
gmake[1]: Leaving directory `/usr/ports/packages/All/postgis1.5/postgis-1.1.5/lwgeom'
gmake: *** [liblwgeom] Error 2
*** Error code 2
Can anyone clarify the best way for me to get postgis installed with the GEOS support needed for the geo functions? Do I in fact need to build from source, or can I enable this after adding the freebsd package?
Thanks,
Theo
Get your email and more, right on the new Yahoo.com
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20061017/fe5f19a4/attachment.html>
