AW: [postgis-users] GEOS Intersection() threw an error! Again
Pierre viallet
pviallet at yahoo.fr
Tue Oct 17 23:52:28 PDT 2006
Thank's a lot Rene and Thomas,
I'm going to switch to geos 3.0.0rc1, and test it !
Regards,
Pierre
----- Message d'origine ----
De : Rene Neidt <r.Neidt at idu.de>
À : PostGIS Users Discussion <postgis-users at postgis.refractions.net>
Envoyé le : Mardi, 17 Octobre 2006, 21h42mn 35s
Objet : AW: [postgis-users] GEOS Intersection() threw an error! Again
Hello Pierre,
we have similar problems.
a few seconds ago we have installed a server with ....
"POSTGIS="1.1.5" GEOS="3.0.0rc1-CAPI-1.2.0" PROJ="Rel. 4.5.0, 19 Apr 2006" USE_STATS"
(on suse linux)
and your query works !
We hope that our problems also will be resolved with the new geos version :-)
Greetings
Rene + Thomas
Von: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] Im Auftrag von Pierre viallet
Gesendet: Dienstag, 17. Oktober 2006 16:10
An: postgis-users at postgis.refractions.net
Betreff: [postgis-users] GEOS Intersection() threw an error! Again
Hi Guy,
I know that i'm not the only one who have TopologyException probelm.
But the folowing exemple was running well in previous version (before geos 2.1.4) and return POINT(0.1,0.1) :
select
astext(intersection(geomfromtext('POLYGON ((0 0, 0 0.5, 0.1 0.5, 0.1 0.1, 0 0))', 27582),
geomfromtext('POLYGON ((0.5 0, 0.1 0, 0.1 0.1, 0.5 0.5, 0.5 0))', 27582)))
I've chechek the validity of the two geom, and i try also
select
astext(intersection(ForceRHR(geomfromtext('POLYGON ((0 0, 0 0.5, 0.1 0.5, 0.1 0.1, 0 0))', 27582)),
ForceRHR(geomfromtext('POLYGON ((0.5 0, 0.1 0, 0.1 0.1, 0.5 0.5, 0.5 0))', 27582))))
Is there a way to work around this pb ?
Does news geos 3.0.0 rc1 and the new binaryOp solve this ?
Regards,
Pierre
Découvrez une nouvelle façon d'obtenir des réponses à toutes vos questions ! Demandez à ceux qui savent sur Yahoo! Questions/Réponses.
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
___________________________________________________________________________
http://fr.answers.yahoo.com
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20061018/8afb75f6/attachment.html>
