[postgis-users] PostGIS 1.1.5 Win32 Binaries for PostgreSQL 8.2 beta 1 available
Mike Leahy
mgleahy at alumni.uwaterloo.ca
Fri Oct 20 11:18:42 PDT 2006
Hello list/David,
I tried using these binaries with the PG 8.2 beta 1 windows binaries,
and when I tried loading PostGIS, I got the following:
postgres=# \i ../share/contrib/lwpostgis.sql
BEGIN
NOTICE: type "histogram2d" is not yet defined
DETAIL: Creating a shell type definition.
psql:../share/contrib/lwpostgis.sql:47: NOTICE: type "histogram2d" is
not yet defined
ERROR: could not load library "D:/PSQL82/lib/liblwgeom.dll": The
specified module could not be found.
psql:../share/contrib/lwpostgis.sql:47: ERROR: could not load library
"D:/PSQL82/lib/liblwgeom.dll": The specified module could not be found.
ERROR: current transaction is aborted, commands ignored until end of
transaction block
psql:../share/contrib/lwpostgis.sql:52: ERROR: current transaction is
aborted, commands ignored until end of transaction block
transaction block
etc....
etc....
etc....
psql:../share/contrib/lwpostgis.sql:3685: ERROR: current transaction is
transaction block
psql:../share/contrib/lwpostgis.sql:3732: ERROR: current transaction is
ROLLBACK
postgres=#
The library is definitely found at "D:/PSQL82/lib/liblwgeom.dll", so I
checked using Dependency Walker, and it seems that the dll isn't linking
to postgres.exe and liblwgeom_c-1.dll (both of which are in the bin
folder). I tried adding the bin folder to the PATH environment
variable, but still no luck. Any guesses?
Thanks in advance for any suggestions,
Mike
TECHER David wrote:
> Hi PostGISers,
> PostGIS 1.1.5 is out!
> [I am waiting Marc does the installer ;-)]
> !! BUT IT IS A TEMPORAY SOLUTION that I give you here!!
> Since the postgis Win32 installer for 1.1.5 is not yet available, I've
> built my own binaries
> from postgresql 8.2beta1 for
> * postgresql 8.2 beta1
> * geos 2.2.3 (As Paul said in a recent a mail, I'm agree with him for
> the idea to wait before
> building geos 3.0.0rc1 on win32 since it is in
> dev version.)
> * proj 4.4.9
> * postgis 1.1.5
> I've built it from the source which was used for the postgreql 8.2 beta1
> available at
> ftp://ftp.fr.postgresql.org/source/v8.2beta1/
> As Marc said and fixed the bug for MinGW (see his recent mail), all
> regression test succeeded!
> pgsql2shp too ;-) (thanks Marc)
> INSTRUCTIONS:
> POSTGREQL:
> Install postgresql 8.2 beta1 o win32 from
> ftp://ftp.fr.postgresql.org/binary/v8.2beta1/win32/
> it should be installed in "C:\Program Files\PostgreSQL\8.2beta1" by default
> - !! INSTALL IT WITHOUT THE OPTIONAL POSTGIS !! -
> POSTGIS:
> U can download the binaries from here
> http://www.davidgis.fr/download/win32/postgis-1.1.5/postgis-1.1.5-win32.zip
> I don't try to build the java drivers (not enough times sorry!)
> unzip it into "C:\Program Files\PostgreSQL\8.2beta1"
> In order to creating a PostGIS Database called "testgis"
> as postgres user do
> createdb testgis
> psql -d testgis -f C:\Program
> Files\PostgreSQL\8.2beta1\share\contrib\lwpostgis.sql"
> Files\PostgreSQL\8.2beta1\share\contrib\lspatial_ref_sys.sql"
> I hope this instructions above will work for you ;-)
> and Marc will have enough times to build the installer ;-)
