[postgis-users] 3D Datum shifts from postgis
Frank Warmerdam
warmerdam at pobox.com
Mon Oct 23 12:40:58 PDT 2006
Paul Ramsey wrote:
> Well, I am pretty sure PostGIS only does transform() in 2d, no matter what. But
> I also suspect that Proj4 only has a 2d internal model, which means at the
> library level nothing may be available either.
> Frank, can you confirm what proj4 provides in terms of 3d shifts?
Paul,
The PROJ.4 pj_transform() function attempts to transform "z" as well
as x and y. Note that datum shifts performed with grid shift files
normally have no z shift. But 3/7 parameter transformations also affect
Z, and if the shift is done strictly ellipsoid to ellipsoid then Z shifts
are also possible.
I think it would be desirable to connect up this Z shifting in pj_transform()
to the Z coordinate of postgis geometries.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
