[postgis-users] A PostGIS-Raster data proposal
Tue Oct 24 19:10:46 PDT 2006
Steve,
Excellent summary of the usual sequence of these conversations.
Marshall, Steve wrote:
> The code that really seems well-adapted to this problem is the Kakadu
> package written by David Taubman, one of the originators of JPEG 2000.
> Unfortunately, this library is not open source.  Kakadu has been
> included as an optional component of other open source projects, like
> GDAL.  However, I think Kakadu's license would come into conflict with
> the GPL used by PostGIS.   I'm not a lawyer, but I think this
> conflict could be overcome if PostGIS could be release under dual
> licenses, such as GPL or LGPL.  Whether or not its desirable to include
> of Kakadu in a PostGIS extension is another question.
As mentioned by others I think the licensing conflicts may be more
fundamental then you suggest.
By the way, I've implemented "virtual" jpeg2000 access in GDAL for
both the Kakadu library and the ECW library.  The ECW library supports
jpeg2000 and ecw by the way.  I suspect it is also possible for the
MrSID library by I haven't done it myself.
> If anyone has knowledge of other JPEG 2000 codecs that have these
> low-level access capabilities, I'd be very happy to hear about them.
> Also, if I've mischaracterized any of the codecs, I'd love to be corrected.
> In any event, I'm curious to see if there is significant interest in an
> implementation of JPEG2000 raster data type within PostGIS.  If so, I
> think I could dedicate a significant amount of my time over the next
> several months, as well as perhaps some funding from my employer,
> depending upon whether some of the issues I raised above can be resolved.
I'm not sure I entirely buy into the idea of using jpeg2000 as a special
native raster data type.  There are a variety of limitations, and odd
performance characteristics with jpeg2000 which would make me nervous.
I would suggest instead the same general approach of treating BLOBs
in the database as seekable objects from which components could be
extracted, but instead of restricting things to jpeg2000, allow any
GDAL supported raster format to be in the database, and use GDAL to
access them in the database.
Actually, when I say "any" format, I really mean any format in GDAL
that supports the virtualization interface where all IO is routed
through VSIFOpenL() and related functions.  This is a lot of the
drivers, but by no means all.  This would also allow use of formats
like tiled GeoTIFF with overviews, from which chunks or overviews
can be efficiently extracted with much better understood performance
characteristics.
If you have the time to work on a prototype, then I'd say go for it.
If you are interested in using GDAL, then I'd be willing to provide
advice and answers on GDAL issues.
PS. I'd encourage you do some sort of performance testing to see
if there is a lot of overhead in doing random seeks in large
toasted blobs in postgres.  I don't understand the mechanism well,
but it seems like it could be an issue, and better to find out
sooner rather than later.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
