[postgis-users] A PostGIS-Raster data proposal
Guido Lemoine
guido.lemoine at jrc.it
Wed Oct 25 00:22:36 PDT 2006
My little bit:
- I came across the JasPer package at
http://www.ece.uvic.ca/~mdadams/jasper/
recently (JPEG-2000 codec in C) . I have only had a brief look at it.
It is mentioned
there that it is included in GDAL. The site states it is Open Source,
but the license
does not look familiar.
- I use JAI (Java Advanced Imaging), which can read and write JPEG2000.
JAI contains
all the operators for image subsampling, ROI extraction etc.
But for the moment, I am happy with storing metadata in Postgis and do
the specific
processing externally (using JAI and JDBC) with image data on disk.
Still, I like the
pgraster idea, as it is probably useful in the JAI/JDBC context as well.
GL
Marshall, Steve wrote:
> > GDAL manages the Kakadu issue by simply providing an adapter and
> leaving the
> > acquisition of the source up to the installer; why would this not work
> > equally well for postGIS ?
> PostGIS has a GPL license which basically says that the source code of
> packages linked to it must also be covered by the GPL. Kakadu has a
> conflicting license, so you put the two packages together in the same
> executable, you either have to honor the GPL and violate the Kakadu
> license, or vice versa. Neither option is legally valid.
> GDAL is distributed under the MIT license, which does not put any
> requirements other packages that might be linked in the same
> executable with GDAL. Thus you can link optional closed-source
> packages to GDAL.
>_______________________________________________
>postgis-users mailing list
>postgis-users at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-users
Joint Research Centre, European Commission
Institute for the Protection and Security of the Citizen (IPSC)
Unit: Support to External Security
Via E. Fermi, 1 TP 267 Ispra 21020 (VA), Italy
Tel. +39 0332 786239 (direct line) Fax. +39 0332 785154
WWW: http://ses.jrc.it
Disclaimer:
Views expressed are those of the individual and do not represent the
views of the European Commission
