[postgis-users] Re: A PostGIS-Raster data proposal
Paul Ramsey
pramsey at refractions.net
Wed Oct 25 21:54:46 PDT 2006
For those who haven't checked, there's some interesting reference
material here:
<http://postgis.refractions.net/support/wiki/index.php?RasterNotes>
P
On 25-Oct-06, at 9:41 PM, Paul Ramsey wrote:
> I should probably add that I have already come within a hair of
> funding some raster-in-database for client use and may yet cross
> that threshold, but the use case is, as Carl says, entirely
> internal to the RDBMS: convert vector features to raster, do raster
> operations, convert the results back out to vectors. Basically
> GRASS-in-a-database. Now that moves are afoot to move some of the
> GRASS analysis algorithms into a C API, this integration approach
> is getting even more interesting to me.
> So I am not against raster-in-the-database in principle, lest
> anyone take my rhetoric the wrong way, I'm just not in favor of it
> as an end in itself.
> Those who don't want to wait for me to cross the threshold should
> move of their own accord to document a design and get agreement
> from the community that the design looks workable.
> I was fond of going to LO route in my flirting with the idea,
> precisely because it made the use of things like GDAL or (in the
> future) GRASS libraries pretty straightforward -- grab a file-
> handle and go. Custom PgSQL types can include an LO reference. I
> never investigated the transactional issues involved, that's an
> interesting point.
> P
> On 25-Oct-06, at 8:04 PM, Carl Anderson wrote:
>> Now that Paul is up on a soap box I feel compelled to throw my 2
>> cents in.
>> I agree with Paul, I have found that is it easier to tune and set
>> up caching for WMS and WC services than it is to try and tune or
>> add caching to database based image sources. In mixed client
>> software environments even more so.
>> If you believe that the speed of GOOGLE Earth comes from massive
>> image caching you might agree.
>> The compelling reason to put cell / grid /raster data into PostGIS
>> has to be bound to one or more use profiles. Each which can be
>> evaluated and understood.
>> Elevation data comes to mind. A DEM is a regular gridded set of
>> elevation samples. Sometimes it is convenient to programmatically
>> convert 2 dimensional LineStrings into 3 dimensional (Z) LineStrings.
>> Looking at this goal, being able to resample a single elvation
>> from an elevation fabric (source).
>> Converting the DEM into a TIN and then representing each polygon
>> in the TIN as a 3D (Z) dimensional plane in PostGIS and creating
>> some sort of resampling function might work better and faster than
>> supporting the original gridded elevation set. The TIN method
>> actually does run faster in my own tests.
>> I am looking for a compelling use case to house Raster in a
>> RDBMS. Client centric reasons are not so strong to me. Reasons
>> compelled by an internal RDBMS issue is stronger.
>> C.
>> Paul Ramsey wrote:
>>> SDE's raster-in-database support is only faster than other
>>> alternatives because ESRI chooses not to make the alternatives
>>> faster. If you are ESRI, what's better for you, optimizing file-
>>> based imagery access, or telling people to buy SDE? Trust me, if
>>> you just want fast access to a large set of imagery, stuff it in
>>> a directory, build a mapserver tileindex on it and serve it as a
>>> WMS service. Raster-in-database for performance is a red-herring
>>> propogated by ESRI and Oracle who have an interest in selling
>>> said databases -- I have no such interest.
>>> Arguments about unified user and access management, and
>>> integrated raster analysis somewhat persuade me, but if people
>>> really want this they are going to need to do it themselves, and
>>> job one of that is creating a design. I would suggest hitting
>>> the wiki, starting to layout some standard table structures and
>>> descriptions of where data goes, and function signatures for
>>> accessing things. Once a design is in place, it is possible for
>>> folks to take a piecemeal approach to implementing things a
>>> function at a time, but until then nothing much will happen
>>> except jawboning.
>>> PS - Copying other people's implementation designs is also
>>> acceptable, though really abstract designs like oracle's
>>> georaster will have a pretty high implementation overhead.
>>> PPS - We have avoided having to design anything in the past by
>>> simply aping the standard, but there is no standard to ape in
>>> this case.
>>> P
>>> On 25-Oct-06, at 3:38 PM, galen at shackprices.com wrote:
>>>> I'm not familiar with the specifics of the implementation, but
>>>> when I was
>>>> contracting for the EPA in New Orleans cleanup effort, we stored
>>>> massive
>>>> multi-gigabyte rasters in a geodatabase using ESRI's (ack!)
>>>> database
>>>> frontend and a MS-SQL backend (it was transparent to users, so
>>>> it could
>>>> have been Oracle). It made image retrieval much faster over the
>>>> network
>>>> and dramatically cut processing time. If we had to build our own
>>>> system,
>>>> it would have been more expensive and time consuming.
>>>> Here's a vote of support for the proposal!
>>>> -Galen
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> postgis-users at postgis.refractions.net
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
