[postgis-users] shp2pgsql not found
Paul Ramsey pramsey at refractions.net
Sat Oct 28 22:56:31 PDT 2006
Sometimes you have to be explicit about where your executable is,
with a ./command syntax:
./shp2pgsql -s -i foo.shp foo > foo.sql
Or, you could explicitly add your pgsql directory to your search path
instead:
export PATH=${PATH}:/usr/local/pgslq/bin
Then your command below should work.
Yours,
Paul
On 28-Oct-06, at 8:50 PM, Salvatore Larosa wrote:
> Sorry my english!
> I have installed postgres/postgis in my Debian Etch on laptop, but
> when start command shp2pgsql it get the error:
> postgres at debian:/usr/local/pgsql/bin$ shp2pgsql -s -1
> /home/sam/Desktop/test_postgis/Dighe.shp test Prova >
> /home/sam/Desktop/test_postgis/test.sql
> -su: shp2pgsql: command not found
> Please help me!
> View this message in context: http://www.nabble.com/shp2pgsql-not-
> found-tf2533044.html#a7057587
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
