[postgis-users] What SRID is the USGS 24k Quad Grid?
Obe, Regina
robe.dnd at cityofboston.gov
Mon Oct 30 08:42:20 PST 2006
Do you know if that maps to a particular SRID in the spatial ref sys
table or do I have to define my own. If I need to define - not sure how
to go about doing that.
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Paul
Ramsey
Sent: Monday, October 30, 2006 11:14 AM
To: lr at paragoncorporation.com; PostGIS Users Discussion
Subject: Re: [postgis-users] What SRID is the USGS 24k Quad Grid?
I've seen that grid once apon a time... is it this?
PROJCS["USA Lambert",GEOGCS["GCS_USA_Sphere",DATUM
["USA_Sphere",SPHEROID["SPHERE",6370977.0,0]],PRIMEM["Greenwich",
0],UNIT["Degree",0.017453292519943295]],PROJECTION
["Lambert_Azimuthal_Equal_Area"],PARAMETER["False_Easting",
0],PARAMETER["False_Northing",0],PARAMETER
["Central_Meridian",-100],PARAMETER["Latitude_Of_Origin",45],UNIT
["Meter",1]]
On 30-Oct-06, at 12:34 AM, Paragon Corporation wrote:
> No that didn't work. The actual data is not in degrees. I think its
> in meters of some sort, but not sure which one. My fear is that its
> more than one SRID like it's a set of UTM ones and so I would have to
> change my SRID for each slice as the UTM zone changes.
> Thanks,
> Regina
> From: Michael Fuhr [mailto:mike at fuhr.org]
> Sent: Sunday, October 29, 2006 10:14 PM
> On Sun, Oct 29, 2006 at 09:34:58PM -0500, Paragon Corporation wrote:
>> I wanted to use the USGS 24K Quad Grid for some statistical analysis.
>> Unfortunately I don't know what the spatial reference system is that
>> is used.
>> The file is located here
>> http://data.geocomm.com/catalog
>> and is the USGS 24Quad Grid file.
> I didn't see any metadata so I'd guess 4267 (longlat NAD27) or maybe
> 4269 (longlat NAD83).
> Michael Fuhr
> postgis-users mailing list
The substance of this message, including any attachments, may be
confidential, legally
privileged and/or exempt from disclosure pursuant to Massachusetts
law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and
delete the material from any computer.
