[postgis-users] How to Delete Records Outside a Polygon?
Michael Fuhr
mike at fuhr.org
Mon Sep 4 17:46:19 PDT 2006
On Mon, Sep 04, 2006 at 03:12:50PM -0600, Bill Thoen wrote:
> I'm trying to reduce a collection of farm fields to only those that fall
> within a county border and so I'm trying to figure out the SQL to delete
> all records in one table whose polygons fall outside a particular
> polygon in another table. For example, I've got farms (farm_id integer,
> the_geom geometry) and I've got counties (fips varchar(5), the_geom
> geometry). I want to remove everything from farms only where not
> intersects(farms.the_geom, counties.the_geom) and counties.fips='17001'.
Something like the following should work. Execute the subquery by
itself before doing the delete to make sure it selects the right
farms; then start a transaction, do the delete, make a few queries
to verify that the delete worked correctly, then commit or roll
back the transaction.
DELETE FROM farms
WHERE farm_id NOT IN (
SELECT f.farm_id
FROM farms AS f
JOIN counties AS c ON c.the_geom && f.the_geom
AND Intersects(c.the_geom, f.the_geom)
WHERE c.fips = '17001'
The above is standard SQL; the following uses the nonstandard
PostgreSQL USING clause:
DELETE FROM farms
USING counties
WHERE counties.fips = '17001'
AND NOT (farms.the_geom && counties.the_geom
AND Intersects(farms.the_geom, counties.the_geom));
Michael Fuhr
