[postgis-users] RE: RE: PostGIS - hibernate - EJB3
Norman Barker
nbarker at ittvis.com
Tue Sep 5 05:48:31 PDT 2006
I have been a bit busy, but it is my intention to write a simple 'spatial' tutorial on EJB3 using the postgis geometry type, the functionality will be simple but should get you started. I know I said I would have it done by last w/end so I will put it top on my priority list.
Apologies for the delay, posting code with no instructions is bad!
Norman
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net on behalf of coster
Sent: Tue 9/5/2006 6:49 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] RE: RE: PostGIS - hibernate - EJB3
hi,
I have the same problem with JBoss and EJB3.
The column is type "oid" instead of "geometry".
I would be very grateful for a solution - here are my postgis-ds.xml and my
persistence.xml:
<datasources>
<local-tx-datasource>
<jndi-name>PostgisDS</jndi-name>
<connection-url>jdbc:postgresql://xxx:5432/tourguide</connection-url>
<driver-class>org.postgis.DriverWrapper</driver-class>
<user-name>xxx</user-name>
<password>xxx</password>
<new-connection-sql>select 1</new-connection-sql>
<check-valid-connection-sql>select 1</check-valid-connection-sql>
<metadata>
<type-mapping>PostgreSQL 8.1</type-mapping>
</metadata>
</local-tx-datasource>
</datasources>
<persistence xmlns="http://java.sun.com/xml/ns/persistence">
<persistence-unit name="tourguide">
<jta-data-source>java:/PostgisDS</jta-data-source>
<properties>
<property name="hibernate.dialect"
value="org.hibernate.dialect.PostgreSQLDialect"/>
<property name="hibernate.hbm2ddl.auto" value="update"/>
<property name="hibernate.show_sql" value="true"/>
</properties>
</persistence-unit>
</persistence>
Thanks!
Christian.
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
> croisfert
> Sent: Monday, August 21, 2006 2:54 AM
> Subject: [postgis-users] RE: PostGIS - hibernate - EJB3
> hi, I am trying to use custom UserType, but it work fine in a pure
> Hibernate
> implementation , but not in JBOSS EJB3, the generated geometry column in
> postgres is of type "oid" instead of "geometry" You have any
> suggestion,
> i am using jboss-EJB-3.0_RC8-FD and postgis 1.1.3 (on postgres 8.1.4)
> thanks.
> Make sure that the usertype is available on your classpath, I have only
> tested it with the Geometry Column type (as the name implies!!), I also
> set up postgis as a datasource within JBoss - postgis-ds.xml, and
> configured the persistence.xml. I am writing up a doc for this shortly;
> just don't have too much time this week.
> Norman
> postgis-users mailing list
View this message in context: http://www.nabble.com/PostGIS---hibernate---EJB3-tf2064211.html#a6146402
Sent from the PostGIS - User forum at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060905/378b55cf/attachment.html>
