[postgis-users] Split One Layer of Polygons With Another Layer of Polygons?
Bill Thoen
bthoen at gisnet.com
Tue Sep 5 14:31:01 PDT 2006
Using PopstgreSQL/PostGIS, what are the steps I need to use to split one
layer of polygons with another layer and also maintain data attrributes
among the polygons that are split? For example, I've got corn and
soybean field polygons that need to be split at the borders of
overlaying CLU (Common Land Unit) polygons, and if a corn field crosses
under a CLU boundary, I want to split the field at the CLU boundary and
copy the orignal field id, crop code and other attributes into the two
(or more) resulting farm field polygons (and probably assign a new
unique polygon id to them all too.)
I'm thinking that the approach would be to create a cursor selection of
CLUs and for each of these find the set of farm fields that overlap it.
Then for each of those farm fields, split them against the CLU polygon
(using Intersection()?) and insert each new polygon with associated data
into a new table, and deleting the orignal farm polygon. Then at the end
merge all the split polygons back into the orignal table and assign
unique ids of all of them.
Is this the right approach? It seems like a bit of a job, but it also
seems like a common enough operation that I'm wondering if there is a
simpler way already available in PostGIS or has somebody written a
function to do this sort of thing?
TIA,
- Bill Thoen
