[postgis-users] Split One Layer of Polygons With Another Layer ofPolygons?
Gilbert, Antoine AGilbert at korem.com
Wed Sep 6 07:37:13 PDT 2006
I wonder what software you talking about :p
-----Original Message-----
Sent: September 6, 2006 8:46 AM
To: Paul Ramsey
Cc: PostGIS Users Discussion
Subject: Re: [postgis-users] Split One Layer of Polygons With Another
Layer ofPolygons?
Thanks! If I didn't ask questions I'd certainly make mountains out of
molehills. One of my big problems seems to be unnlearning the techniques
capabilities of the software I have been using before I ran across
PostgreSQL and PostGIS.
On Tue, Sep 05, 2006 at 06:06:45PM -0700, Paul Ramsey wrote:
> CREATE TABLE new_fields AS
> SELECT intersection(f.the_geom, c.the_geom) as the_geom, f.*,
c.clu_name
> FROM fields f, clu c
> WHERE
>   f.the_geom && c.the_geom
> AND
>   Intersects(f.the_geom, c.the_geom)
> On 5-Sep-06, at 2:31 PM, Bill Thoen wrote:
> >Using PopstgreSQL/PostGIS, what are the steps I need to use to
> >split one layer of polygons with another layer and also maintain
> >data attrributes among the polygons that are split? For example,
> >I've got corn and soybean field polygons that need to be split at
> >the borders of overlaying CLU (Common Land Unit) polygons, and if a
> >corn field crosses under a CLU boundary, I want to split the field
> >at the CLU boundary and copy the orignal field id, crop code and
> >other attributes into the two (or more) resulting farm field
> >polygons (and probably assign a new unique polygon id to them all
> >too.)
> >I'm thinking that the approach would be to create a cursor
> >selection of CLUs and for each of these find the set of farm fields
> >that overlap it. Then for each of those farm fields, split them
> >against the CLU polygon (using Intersection()?) and insert each new
> >polygon with associated data into a new table, and deleting the
> >orignal farm polygon. Then at the end merge all the split polygons
> >back into the orignal table and assign unique ids of all of them.
> >Is this the right approach? It seems like a bit of a job, but it
> >also seems like a common enough operation that I'm wondering if
> >there is a simpler way already available in PostGIS or has somebody
> >written a function to do this sort of thing?
> >TIA,
> >- Bill Thoen
> >_______________________________________________
> >postgis-users mailing list
> >postgis-users at postgis.refractions.net
> >http://postgis.refractions.net/mailman/listinfo/postgis-users
