[postgis-users] Problem with date fields in shp2pgsql
Bruce Rindahl
rindahl at lrcwe.com
Fri Sep 8 15:20:26 PDT 2006
I am converting a shapefile to PostGIS where one of the fields is a date
field. If there is data in the field everything works fine. However if the
field is null, shp2pgsql parses the insert statement as:
INSERT INTO "test" (...,"saledate",...) VALUES (...,'',...);
pgsql will then throw an error saying:
ERROR: invalid input syntax for type date: ""
If I change the ...,'',... to ...,NULL,... then the query runs.
Should shp2pgsql check for this?
Bruce Rindahl
