[postgis-users] ogr2ogr creating shapefile
Frances Collier fcollier at preparedresponse.com
Tue Sep 12 15:00:42 PDT 2006
Okay, I didn't know that it needed an attribute. Thanks for the info.
Frances
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Bruce
Rindahl
Sent: Tuesday, September 12, 2006 2:55 PM
To: 'Frances Collier'
Cc: 'PostGIS Users Discussion'
Subject: RE: [postgis-users] ogr2ogr creating shapefile
Your function getpop() returns two geometries - pnt and pop.  I wanted to
confirm that with the first query.  A shapefile needs one geometry and at
least one attribute.  As an example I just created columns of the x and y
coordinates of the pnt geometry and the pop for the shapefile.  X() and Y()
are standard PostGIS functions.
Bruce
From: Frances Collier [mailto:fcollier at preparedresponse.com]
Sent: Tuesday, September 12, 2006 3:49 PM
To: rindahl at lrcwe.com
That worked, of course, and thank you very much. The table now has the FID,
shape, X, and Y in it. I understand what they all are, but I don't
understand why. If you don't mind too much, would you explain (or point me
to an explanation of) why the x and y needed to be included?
-Frances Collier
Sent: Tuesday, September 12, 2006 2:24 PM
Now try:
Pgsql2shp -f D:\myshapefile.shp -u postgres -P postgres mydb 'select pop,
X(pnt) as x, y(pnt) as y from getpop()'
This should give you a shapefile of the buffers and the x and y coordinates
of the points as attributes in the table.
Bruce
Sent: Tuesday, September 12, 2006 3:04 PM
Sure:
pnt|pop
0101000020FF7F000034BBEEAD48635EC06E3480B7402C4840|"0103000020FF7F0000010000
002200000034BBEEAD48435EC06E3480B7402C4840B1C31E16E6435EC01E01625BC41F484010
881F42B8455EC09E88D9D4C213484049ABC547AD485EC076DB0C41B2084840CA39880FA84C5E
C0533AB37AFFFE47409609B57281515EC0741B2EEB09F74740995F9BBC09575EC0DED2E1DF1F
F147407F9BDF7F0A5D5EC0D047E0877BED474008B5EEAD48635EC06E3480B740EC4740CFCEFD
DB86695EC0FF42E0877BED4740680B429F876F5EC06CC9E1DF1FF147408F6228E90F755EC0BD
0D2EEB09F74740E433554CE9795EC0DF28B37AFFFE474044C41714E47D5EC0F0C60C41B20848
409FE9BD19D9805EC0D171D9D4C21348404FB0BE45AB825EC0E9E8615BC41F484034BBEEAD48
835EC0BF1B80B7402C484020B5BE45AB825EC0884F9E13BD38484011F3BD19D9805EC070C926
9ABE444840FAD11714E47D5EC0E178F32DCF4F48405845554CE9795EC0151D4DF48159484015
7728E90F755EC0B23FD283776148403622429F876F5EC08C8C1E8F6167484004E7FDDB86695E
C03B1C20E7056B4840B7CDEEAD48635EC06E3480B7406C4840B4B3DF7F0A5D5EC0AE2A20E705
6B484066769BBC09575EC0E2A81E8F616748401C1EB57281515EC0D568D283776148403E4B88
0FA84C5EC071514DF48159484000B9C547AD485EC072B6F32DCF4F484082911F42B8455EC0D9
0D279ABE44484082C81E16E6435EC028989E13BD38484034BBEEAD48435EC0CB6580B7402C48
4034BBEEAD48435EC06E3480B7402C4840"
I separated the columns with the "|" symbol.
Frances Collier
Sent: Tuesday, September 12, 2006 1:44 PM
Can you post the result of:
Select * from mypop() limit 1
Bruce Rindahl
Sent: Tuesday, September 12, 2006 2:40 PM
To: rindahl at lrcwe.com; 'PostGIS Users Discussion'
Bruce,
Well, I fixed the query so I'm only calling one of the two columns ("select
pop from getpop()"), and I still get the same error. Do I need to be
querying another column in addition to the geometry one? Perhaps it's the
way I've written my function.
First I created my own type: myset(pnt geometry, pop geometry). My function
returns a setof myset. In the function, I take a linestring, get the
individual points, and then simply call the buffer function on each point.
(Does this make enough sense?) So, I guess I'm really asking if the myset
type is the problem.
Thank you for your time.
Frances Collier
Rindahl
Sent: Tuesday, September 12, 2006 1:10 PM
To: 'PostGIS Users Discussion'
An ESRI shapefile can only have one type of geometry.  You can't have a
point and a polygon in one shapefile.
Bruce Rindahl
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Frances
Collier
Sent: Tuesday, September 12, 2006 2:07 PM
Thank you Bill. That worked wonderfully.
Now, I have another problem. When I try to open the shape file, it breaks.
The ESRI software says that the number of shapes does not match the number
of table records. When I open the .dbf there are no records. The getPop()
function is returning a point column and a polygon column. Does it need more
than?
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Bill
Thoen
Sent: Tuesday, September 12, 2006 12:50 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] ogr2ogr creating shapefile
Oddly enough, 'Select' must be lower case for this to work.
On Tue, Sep 12, 2006 at 12:32:46PM -0700, Frances Collier wrote:
> Thank you for your reply, David. I did copy and post the question to the
> gdal-dev mailing list. In the meantime, though, I tried using pgsql2shp.
My
> exact syntax:
> Pgsql2shp -f D:\myshapefile.shp -u postgres -P postgres mydb 'Select *
from
> getPop()'
> The print out is: Initializing... Querying for attributes: ERROR: syntax
> error at or near "Select" at character 152  Now, I've tried putting both
> single and double quotes around mydb and around the select statement. If I
> don't have the single quotes around the select statement it returns back
an
> error stating that the table Select does not exist.
> And getPop() is a function that I wrote. If you'd like that code, let me
> know.
> Thank you,
> Frances Collier
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of TECHER
> David
> Sent: Monday, September 11, 2006 4:56 PM
> Hi Frances,
> I'm used to using ogr2ogr but I've never had problems.
> Never see this error before! For me to understanding what is getPop() in
> your query???
> What about using pgsql2shp instead of ogr2ogr ??? (see
> http://postgis.refractions.net/docs/ch04.html#id2524054)
> example: pgsql2shp -f your_shapefile.shp your_database your_query
> for us to see if U have error too with this tool
> For the error U give, it seems better to ask on gdal mailing list!
> Frances Collier a écrit :
> >Hello all,
> >I have been trying to figure out how to create a shapefile using ogr2ogr.
I
> >haven't been able to find much on it through google and the user pages so
I
> >thought one of you might be able to help.
> >Here's my statement:
> >ogr2ogr -f "ESRI Shapefile" test "PG:dbname=mydb host=localhost
> >user=postgres password=postgres" -sql "Select pop from getPop()"
> >When I click enter I get an Application Error that states the memory
could
> >not be "read". I'm sure it's in my syntax, but I can't figure it out. I
> >would like to know if there are other ways to accomplish this as well.
> >Thank you,
> >Frances Collier
> >_______________________________________________
> >postgis-users mailing list
> >postgis-users at postgis.refractions.net
> >http://postgis.refractions.net/mailman/listinfo/postgis-users
> --david;
> http://www.postgis.fr
> http://www.davidgis.fr
___________________________________________________________________________
> Dcouvrez un nouveau moyen de poser toutes vos questions quelque soit le
> sujet !
> Yahoo! Questions/Rponses pour partager vos connaissances, vos opinions et
> vos expriences.
> http://fr.answers.yahoo.com
