[postgis-users] Exporting to ESRI's ArcGIS
Graham Stewart graham at mobilefoundry.net
Wed Sep 13 14:10:07 PDT 2006
Michael,
You should be able to install postgis locally on your windows machine
and then use pgsql2shp to connect to the remote server (using the -h
host option)
Graham
Michael de Armas (Micotan) wrote:
> Hi,
> if I wanted to query my PostGIS data and send the resulting geometry
> via email to someone who uses ESRI software, which would be the best
> way to go?
> I have to do it from a client application (windows). I cannot use
> Pgsql2shp because I don't have access from the application to
> the Pgsql2shp command on the Linux server hosting the Postgre DB.
> Any ideas?
> Thanks,
> Michael.
> postgis-users mailing list
