[postgis-users] Exporting to ESRI's ArcGIS
Bruce Rindahl
rindahl at lrcwe.com
Wed Sep 13 14:32:57 PDT 2006
There is an extension called pgarc that that has most of the functionality
you might be looking for. See:
http://pgarc.sourceforge.net/
I have taken the code and made some changes. I ported it to the new code
for 9.x. It will load the extent of the display view and defines the
projection for the resultant shapefile that is loaded on the local machine.
It can write to a PostGIS database but the functionality is limited - I
haven't really needed it.
I have had limited success in contacting the authors of pgarc to see if they
are interested in updating the project.
Hope this helps.
Bruce Rindahl
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of P Kishor
Sent: Wednesday, September 13, 2006 3:25 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Exporting to ESRI's ArcGIS
Sorry, no help here (am curious about this meself), but I have a
related question -- anyone figured out how to view PostGIS data in
ArcGIS?
On 9/13/06, Michael de Armas (Micotan) <michael.dearmas at micotan.com> wrote:
> Thanks, for the suggestion.
> Is that the only way? Let's say that, for some reasons, I cannot install
> PostGIS in the PC where the app will run and/or I don't want to call an
> external program to do the job.
> I was thinking something like saving the geometry to a GML file, but I
don't
> know if ESRI could read the GML that PostGIS generates.
> postgis-users mailing list
Puneet Kishor http://punkish.eidesis.org/
Nelson Inst. for Env. Studies, UW-Madison http://www.ies.wisc.edu/
Open Source Geospatial Foundation https://edu.osgeo.org/
