[postgis-users] Exporting to ESRI's ArcGIS
P Kishor
punkish at eidesis.org
Wed Sep 13 14:34:55 PDT 2006
On 9/13/06, Michael de Armas (Micotan) <michael.dearmas at micotan.com> wrote:
> P Kishor,
> I heard that exists an extension for using PostgreSQL DB from ArcGIS, but it
> has to be with ArcGIS 9.02, but I only heard it.
Interesting. So, if you (we) can figure out where such an extension
exists (what is it an extension to -- to PostGIS, thereby making it
appear like an ArcGIS compatible datasource, or to ArcGIS, thereby
making it capable of reading PostGIS?), you might also be helped here.
You could then log on to PostGIS with your ArcGIS, export the data and
send it to your buddy who can then use it with her/his ArcGIS.
> By the way, how can I make my messages to appear in the same thread?
I am not sure what you mean? Just hit reply, and it will be in the
same thread, no?
Puneet Kishor http://punkish.eidesis.org/
Nelson Inst. for Env. Studies, UW-Madison http://www.ies.wisc.edu/
Open Source Geospatial Foundation https://edu.osgeo.org/
