[postgis-users] Shp2pgsql - ability to generate a linestring table
Michael Fuhr
mike at fuhr.org
Fri Sep 15 13:34:32 PDT 2006
On Fri, Sep 15, 2006 at 12:15:56PM -0700, Stewart Nimmo wrote:
> When running "shp2pgsql" on a polyline shape file, the resulting table is
> always a geometry type "multilinestring". I am expecting and require a
> geometry type of "linestring" .
> Is "multilinestring" the default geometry type for polyline shape files
> being converted with shp2pgsql.
Apparently so. The SetPgType() function in loader/shp2pgsql.c has
the following code:
case SHPT_ARC: /* PolyLine */
pgtype = "MULTILINESTRING";
wkbtype = MULTILINETYPE ;
pgdims = 2;
break;
Maybe I'm missing something but I don't see an option to change
that. One possible way around this behavior would be to use -w to
get WKT format, then filter the output before loading it into the
database. Here's a simple example:
shp2pgsql -Dw filename.shp tablename | \
perl -pe 's/MULTILINESTRING/LINESTRING/g;
s/(LINESTRING)\s*\(\((.*?)\)\)/$1($2)/g' | \
psql dbname
This worked for me in simple tests but I'd recommend examining the
filter's output before using it.
Michael Fuhr
