[postgis-users] How to instanziate the Geometry class from the geometry string?
Markus Schaber schabi at logix-tt.com
Wed Sep 20 04:28:10 PDT 2006
Hi, Francesco,
martinelli at pi.ingv.it wrote:
> looking at the same package (org.postgis.binary) I also tried for the
> "derializer" the following snippet:
>     BinaryParser parser = new BinaryParser();
>     Geometry geom = parser.parse((String)source);
> and (at least "apparently") it worked without the need of looking for
> SQLException, which is required for:
>     Geometry geom = PGgeometry.geomFromString((String) source);
> requires a try-catch.
> Is there a reson for preferring the second one?
The second one can also parse Text Representations (like "POINT(23
42)"). If you don't need it, use the first one.
Btw, BinaryParser is reusable, so you can reuse the same instance for
several geometries.
HTH,
Markus
Markus Schaber | Logical Tracking&Tracing International AG
Dipl. Inf.     | Software Development GIS
Fight against software patents in Europe! www.ffii.org
www.nosoftwarepatents.org
