[postgis-users] strange compile problems
Michael Fuhr
mike at fuhr.org
Wed Sep 20 21:39:55 PDT 2006
On Wed, Sep 20, 2006 at 05:03:00PM -0700, Dylan Beaudette wrote:
> cd postgresql-8.1.3
> ./configure
> make
> sudo make install
Where did this install PostgreSQL? If you didn't set --prefix when
you ran configure then everything probably went under /usr/local/pgsql.
> gcc -march=opteron -DUSE_VERSION=81 -DPOSTGIS_LIB_VERSION='"1.1.3"' -DPOSTGIS_VERSION='"1.1
> USE_GEOS=1 USE_PROJ=1
> USE_STATS=1"' -DPOSTGIS_SCRIPTS_VERSION='"1.1.3"' -DPOSTGIS_BUILD_DATE='"2006-09-20
> 23:31:02"' -I/usr/local/include -DUSE_PROJ -I/usr/include/postgresql/8.1/server -DAUTOCACHE_BBOX=1 -DUSE_STATS -Wall -g -O2 -fPIC -fexceptions -DUSE_GEOS -I/usr/local/include -c -o
> liblwgeom.o liblwgeom.c
> In file included from liblwgeom.c:26:
> lwgeom_pg.h:4:22: error: postgres.h: No such file or directory
> lwgeom_pg.h:5:29: error: utils/geo_decls.h: No such file or directory
> lwgeom_pg.h:6:18: error: fmgr.h: No such file or directory
The above gcc command is looking for PostgreSQL header files in
/usr/include/postgresql/8.1/server, which probably isn't where the
earlier PostgreSQL installation put them.
> PGSQL: /usr/bin/pg_config
This looks like the culprit. Is /usr/bin/pg_config from a previous
installation of PostgreSQL? Perhaps installed via a pre-built
package and nobody installed the package with the server-side header
files? Did your most recent PostgreSQL build install a file named
/usr/local/pgsql/bin/pg_config?
Michael Fuhr
