[postgis-users] extent buffer issue
"R. Müller"
r.mueller at unicomp-berlin.de
Thu Sep 21 07:44:21 PDT 2006
hi to all,
the following test-case produces a floating point exception on my box:
select buffer(extent(geomfromtext('Point(1 1)',-1)),1);
the exact error message is in german (sorry for that):
FEHLER: Fliesskommafehler
DETAIL: Eine ungueltige Fliesskommaoperation wurde signalisiert. Das
bedeutet wahrscheinlich ein Ergebnis ausserhalb des gueltigen Bereiches
oder eine ungueltige Operation, zum Beispiel Division durch null.
and means (freely translated) :
ERROR : floating point exception
DETAILS : an invalid floating point operation was detected. which
probably means that a result is out of valid range or invalid operation,
for instance division by zero.
my postgis-version is :
POSTGIS="1.1.0CVS" GEOS="2.2.2" PROJ="Rel. 4.4.9, 29 Oct 2004" USE_STATS
DBPROC="0.3.1" RELPROC="0.3.1"'
my postgresql-version is :
PostgreSQL 8.0.8 on x86_64-pc-linux-gnu, compiled by GCC
x86_64-pc-linux-gnu-gcc (GCC) 3.4.6 (Gentoo 3.4.6-r1, ssp-3.4.5-1.0,
pie-8.7.9)
my box is :
Linux 2.6.10 #2 SMP Tue Feb 15 14:14:46 CET 2005 x86_64 AMD Athlon(tm)
64 Processor 3500+ GNU/Linux
does anybody know this issue ?
regards
ronald
