[postgis-users] Stuck: Table within a table?
David William Bitner bitner at gyttja.org
Thu Sep 21 14:02:17 PDT 2006
You'll need to do a join limiting the data by you geographic constraints
like:
select counties.*, states.name from counties,states where within(
counties.the_geom,states.the_geom)
On 9/21/06, Steve Benzo <steve_benzo at yahoo.com> wrote:
> Hi,
> In a particular Postgis/postgres database, I have
> several  geographic tables, countya, countyb, etc. I
> would like to have a way to feed the within or contain
> function a state's extent to find out which counties
> are within a particular state. I've tried a few
> iterations of queries without any luck, and so I was
> hoping someone could point me in the right direction,
> as far as the base SQL postgis statement to allow me
> to accomplish this.
> So far, I was thinking I could loop through the each
> of the tables, use the within command with the state's
> extent and the county's extent, and see if it returns
> true. The problem I'm having is, like I mentioned,
> getting this SQL statement together.
> Many thanks
> __________________________________________________
> Do You Yahoo!?
> Tired of spam?  Yahoo! Mail has the best spam protection around
> http://mail.yahoo.com
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060921/b5d18112/attachment.html>
