[postgis-users] Problem with pgsql function
palmerj at xtra.co.nz
Thu Sep 21 17:42:48 PDT 2006
I have had problems with creating a pgsql function:
CREATE OR REPLACE FUNCTION bde.shift_point(shape geometry)
RETURNS GEOMETRY AS
$BODY$
DECLARE
x DOUBLE PRECISION;
y DOUBLE PRECISION;
z DOUBLE PRECISION;
srid INTEGER;
new GEOMETRY;
BEGIN
IF ( geometrytype(shape) <> 'POINT' ) THEN
RETURN NULL;
END IF;
x := x(shape);
y := y(shape);
z := z(shape);
srid := srid(shape);
--RAISE NOTICE 'x=%, y=%, z=%, srid=%', x, y, z, srid;
x := x - 160;
IF ( x < -180 ) THEN
x := x + 360;
END IF;
new := MakePoint( x, y, z);
IF srid THEN
new := SetSRID(new, srid);
END IF;
RETURN new;
END;
$BODY$
LANGUAGE 'plpgsql' IMMUTABLE;
I get the following error:
ERROR: syntax error at or near "(" at character 13
QUERY: SELECT $1 ( $2 )
CONTEXT: SQL statement in PL/PgSQL function "shift_point" near line 11
LINE 1: SELECT $1 ( $2 )
If I prefix the postgis x, y, z, setsrid functions with the schema 'public'. The function parses ok.
My search path environment variables are:
public, bde, bdewtn, comp_test, unloads, gdbcrs, crsrpt, audit
my postgis version is:
POSTGIS="1.1.2CVS" GEOS="2.2.1-CAPI-1.0.1" PROJ="Rel. 4.4.9, 29 Oct 2004" USE_STATS
postgresql server version = 8.1.2 linux redhat 9.0
Thanks
Jeremy
