[postgis-users] Expanding a geometry
Nicolas Ribot nicky666 at gmail.com
Fri Sep 22 06:53:58 PDT 2006
> scale() and affine() should do that.
> the transform-process doesn't depend on complexity of geometry. it
> should work for every geometry, since it is just a transforming of
> single point the geometry consists of.
> the topology will not change during transforming.
> postgis does the same while transforming from one coordinate system to
> another.
Thanx for the hint, Ronald.
I will look closely at this solution
Nicolas
