[postgis-users] Expanding a geometry
Brian Timoney
brian at thetimoneygroup.com
Fri Sep 22 09:28:18 PDT 2006
Nicolas:
Here's a blog entry that talks about the very topic--
http://www.eicher-gis.com/Blog/2006/06/how-to-scale-dataset.html
I noodled with the same issue awhile back and vaguely remember that
a) For high quality results it's best to apply a transformation to geometries
in a cartesian-type projection (i.e. where the x and y values represent
consistent distances).
b) That even after I scaled my dataset I had to translate() the geometry so it
shared the same center point as my original geometry.
Again, I could've been doing something very wrong; but I recall these hiccups in
particular.
**When you figure it out, please share with the list your solution with a sample
of the SQL statements you used.
Thanks,
Brian
The Timoney Group
518 17th Street
Suite 430
Denver, CO 80206
Ph: (303) 929-3722
Fax: (303) 571-4304
www.thetimoneygroup.com
