[postgis-users] Problem with pgsql function
Jeremy Palmer
palmerj at xtra.co.nz
Fri Sep 22 17:51:53 PDT 2006
He is an example of why translate (unless I wrap a case statement around it
to deal with points that cross the 180° line) will not work even with a
point.
Example query:
SELECT COO.value1,
COO.value2,
ASTEXT(NOD.shape) AS ORGINAL,
ASTEXT(shift_point(NOD.shape, true)) AS SHIFT,
ASTEXT(translate(NOD.shape, 160, 0)) AS TRANSLATE
FROM crs_mark_name MKN,
crs_mark MRK,
crs_coordinate COO,
crs_node NOD
WHERE MRK.id = MKN.mrk_id
AND COO.nod_id = MRK.nod_id
AND NOD.id = MRK.nod_id
AND MKN.name = 'CHAT'
AND MKN.type = 'CODE'
AND NOD.status = 'AUTH'
AND COO.status = 'AUTH'
AND COO.cos_id = 109;
Real latitude: -43.955786822800
Real latitude: -176.565839634400
Stored geometry: POINT(23.4341603667 -43.9557868167)
shift_point function: POINT(-176.5658396333 -43.9557868167)
Translate: POINT(183.4341603667 -43.9557868167)
Notice that the shift_point function will return the point west of
Grenwich, not east like translate
Cheers
Jeremy
_____
Sent: Saturday, 23 September 2006 10:02 a.m.
To: 'Jeremy Palmer'; postgis-users at postgis.refractions.ne
Subject: RE: [postgis-users] Problem with pgsql function
It will definitely work for points which was your example. Do you have a
valid polygon geometry that crosses 180? I mean do you have a polygon with
corners at -179,-31 179,-29 and have that stored as a 2 degree box or is it
2 degrees high and 358 degrees wide ?
Bruce
_____
Sent: Friday, September 22, 2006 3:57 PM
To: postgis-users at postgis.refractions.ne
Cc: rindahl at lrcwe.com
Thanks for the tip, but the translate function (which uses the affine
transform function) will not work on geometries that cross the 180°
longitude line will it? Otherwise your right, I should use it.
Cheers
Jeremy
<< "Bruce Rindahl" rindahl at lrcwe.com
<< Have you considered using the translate() function? I would do exactly
what
<< you are coding and it will work on all geometries.
<< Bruce Rindahl
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060923/1f5b0aa2/attachment.html>
