[postgis-users] PostGIS and GEOS on FreeBSD 4.11: problem with libstdc++.so.6
Toomas Aas toomas.aas at raad.tartu.ee
Mon Sep 25 11:29:00 PDT 2006
Hello!
I installed the following back in June:
PostgreSQL 8.1.4
GEOS 2.2.1
PostGIS 1.1.2
All this was installed onto FreeBSD 4.11 server, using the FreeBSD ports
collection. During installing, when I read the PostGIS documentation, I
found the following note:
If you plan to use GEOS functionality you might need to explicitly link
PostgreSQL against the standard C++ library:
LDFLAGS=-lstdc++ ./configure [YOUR OPTIONS HERE]
This is a workaround for bogus C++ exceptions interaction with older
development tools. If you experience weird problems (backend
unexpectedly closed or similar things) try this trick. This will require
recompiling your PostgreSQL from scratch, of course.
It said that I *might* need to use this trick, but I couldn't figure out
how to make sure I need it, so I decided not to modify my existing
PostgreSQL build.
Now for the first time I tried to use some simple PostGIS functionality:
select geomfromtext('') ;
The response to that was less than encouraging:
ERROR:  could not load library
"/usr/local/lib/postgresql/liblwgeom.so.1": dlopen
(/usr/local/lib/postgresql/liblwgeom.so.1) failed: Shared object
"libstdc++.so.6" not found, required by "libgeos_c.so.1"
CONTEXT:  SQL function "geomfromtext" statement 1
The problem with this message is that all these library files actually
do exist and are listed in output of 'ldconfig -r', so I don't
understand why libstdc++.so.6 can't be found. Does this qualify as a
"weird problem (backend unexpectedly closed or similar thing)",
indicating that I need to rebuild PostgreSQL?
To make life even more interesting, building GEOS on FreeBSD 4.11 pulled
in GCC 3.4 as a dependency and used that to compile itself, whereas
PostgreSQL and PostGIS got built with GCC 2.95, which is standard in
FreeBSD 4. So I actually have two versions of lstdc++:
/usr/lib/libstdc++.so.3
and
/usr/local/lib/gcc/i386-portbld-freebsd4.11/3.4.6/libstdc++.so.6
I wonder if I should perhaps try to build PostgreSQL and PostGIS with
GCC 3.4, so they all use the same C++ libraries?
Thanks in advance for any ideas,
Toomas Aas
