[postgis-users] -- configure: error: PostgreSQL is required by PostGIS Installing PostGIS --
Rafael Orta
rorta_us at yahoo.com
Tue Sep 26 19:53:51 PDT 2006
Hello Everybody
I installed PostgreSQL 8.1 on Red Hat Ent 4.0 and it seems to be working fine. I am proceding to install Postgis 1.1.3 from the .gz file following the instructions in the manual.
It says to uncompress and copy the posgis software on the [postgresql source tree]/contrib. To be honest I am not sure what is this directory, I installed from .rpm files , however I did a find on my disk looking for the contrib directory and found /usr/local/pgsql/share/contrib , so I assume that this is
the directory the installation manual refers to.
When I try to do the make file I get
[root at spatial postgis-1.1.3]# cp Makefile.config.in Makefile.config
[root at spatial postgis-1.1.3]# make
./configure
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking whether ln -s works... yes
checking for iconv_open in -liconv... no
checking for libiconv_open in -liconv... no
checking for iconv_open in -lc... yes
checking how to run the C preprocessor... gcc -E
checking for egrep... grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking iconv.h usability... yes
checking iconv.h presence... yes
checking for iconv.h... yes
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking for pg_config... no
make: *** [config.status] Error 1
Any idea what could be wrong?
I couldn't install the postgress wxGTK-devel-2.6.3-2.6.3.2.1.i686.rpm because
of the error below and did not know where to get gtk2-devel-2.4.13-12.i386.rpm
netiher if it is neccesary.
[root at spatial PgadminIII]# rpm -ihv wxGTK-devel-2.6.3-2.6.3.2.1.i686.rpm
error: Failed dependencies:
gtk2-devel is needed by wxGTK-devel-2.6.3-2.6.3.2.1.i686
Suggested resolutions:
Thanks in advance
Rafael Orta
Rafael Orta Phone: (609)-330-3193
Sr. Oracle DBA Fax: (856)-642-7679
Technical Manager
Oraprofessionals Email: rorta_us at yahoo.com
Do you Yahoo!?
Get on board. You're invited to try the new Yahoo! Mail.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060926/e05a2b0c/attachment.html>
