[postgis-users] Legislative District Lookup
J.C. Quirin jcquirin at ppmns.org
Wed Sep 27 17:18:25 PDT 2006
I am trying to code up a legislative district finder for the upcoming
elections.   My plan is to have the user enter their address, pass
that through the free geocoder.us system, take the lat/long
coordinates that it returns, and do an intersect query to the PostGIS
system.    I have loaded a PostGIS db with a couple of the shape
files from this site:
http://www.commissions.leg.state.mn.us/gis/html/download.htm
(I am currently doing my testing with the congressional district one
-- found in con02.zip -- because I figure that should be most
forgiving.)  I loaded that data into a table named mn_cong_2002 by
using the command:
shp2pgsql c2002.shp mn_cong_2002 > mn_cong_2002.sql
(and then imported that sql into the db, of course)
The query I am using (hard-coded for now) is as follows:
SELECT district FROM mn_cong_2002 WHERE (the_geom && makepoint
(-93.294325, 44.949265));
Unfortunately, it's not returning anything (despite those coordinates
being right smack-dab in the middle of Minneapolis).
I'm a complete newbie when it comes to this stuff, so I don't assume
at all that my queries are correct.  I have checked the coordinates
w/ google maps, and those are correct, but I'm not sure if I'm doing
the makepoint() correctly.
Any ideas?
Thanks in advance!
