[postgis-users] How to identify start node and end node in shortest_path_astar when the user click 2 points on the map?
Anton A. Patrushev
anton at orkney.co.jp
Thu Sep 28 01:04:17 PDT 2006
Hi Nguyen
You can use Distance function of PostGIS.
Here is an example:
SELECT Distance(geom_column, GeomFromText('POINT(x y)',
projection_code)) AS dist
FROM table_name
ORDER BY dist LIMIT 1";
where
geom_column - the name of the column which contains geometry;
'x y' - coordinates of your point divided by space;
projection_code - the code of projection you're using;
table_name - the name of the table.
It will search in entire table, so it will be nice to apply a filter to
the search, but anyway you'll have an idea.
Good luck!
Anton A. Patrushev
Software Engineer
Orkney, Inc.
6F JA-Kyosai Yokohama Building,
1-2 Kaigandori, Naka, Yokohama 231-0002 JAPAN
Tel 81-45-228-3320 Fax 81-45-228-3321
www.orkney.co.jp
> Hi everybody,
> I'm doing a project which needs to find a shortest path between two
> user's clicked points. I already installed successfully pgRouting.
> I use this function:
> SELECT * from shortest_path_astar('SELECT gid as id, source, target,
> length as cost, x1, y1, x2, y2 FROM roads', 3, 7, false, false);
> But the problem is that I can't identify exactly the start node and
> end node to find path (How to identify node 3 and node 7?). I already
> have the start point and end point of the user. But they don't select
> correctly the points on my roads. So I can't draw the path correctly
> on the map (The path begins with their start clicked point and ends
> with their end clicked point)
> Anybody has experiences with this? Please help me!
> Thanks so much.
> postgis-users mailing list
