[postgis-users] Indexes not being used
Paul Ramsey
pramsey at refractions.net
Mon Apr 2 09:58:30 PDT 2007
It's running in 1 millisecond, what's the problem? If your tables are
small, it will ignore the indexes because the cost of sequence scanning
is lower than the index scan cost.
P
Pedro Doria Meunier wrote:
> Hi all (with a special wink to Regina ;- )
> This is the query not using indices:
> SELECT parish,county,geometry FROM pt_madeira_toponymy as t WHERE
> parish=upper('se') AND
> t.geometry && geomfromtext('POINT(-16.9213592631455
> 32.6437878212273)',4326) AND
> intersects(geomfromtext('POINT(-16.9213592631455
> 32.6437878212273)',4326), t.geometry);
> As you can plainly see it checks if a point is inside some polygon.
> EXPLAIN ANALYZE returns this:
> "Seq Scan on pt_madeira_toponymy t (cost=0.00..3.03 rows=1 width=96)
> (actual time=1.086..1.278 rows=1 loops=1)"
> " Filter: ((parish = 'SE'::text) AND (geometry &&
> '0101000020E61000009B135F33DEEB30C0FFDDAAA367524040'::geometry) AND
> intersects('0101000020E61000009B135F33DEEB30C0FFDDAAA367524040'::geometry,
> geometry))"
> "Total runtime: 1.312 ms"
> The toponymy has two indices: one for 4326 and another for 32628 using GiST.
> Is the intersects function not using indices at all??
Paul Ramsey
Refractions Research
http://www.refractions.net
Phone: 250-383-3022
Cell: 250-885-0632
