[postgis-users] newbie install problem with GEOS
trobertson at gbif.org
Tue Apr 3 12:07:50 PDT 2007
I am newbie to POSTGIS and to my mac, and banging my head against the desk
trying to get it to install.
I have POSTGRES installed and working I thought I had POSTGIS working
only to find that when I try and do a CONTAINS() I get the "you need to
build with GEOS" message...
So, I try and follow the destructions, I downloaded PROJ4 and GEOS and in
both do:
su root
./configure
make
make install
then copy the POSTGIS to the POSTGRES/contrib directory.
I change the Makefil.contrib to have
USE_GEOS=1
GEOS_DIR=/usr/local
USE_PROJ=1
PROJ_DIR=/usr/local
and when I run the ./configure in the
/usr/local/src/postgres/postgresql-8.2.3/contrib/postgis-1.2.1 I get
checking for geos-config... no
checking for proj... no
and the Makefile.config gets overridden to have 0's again where I set it
to 1...
Is GEOS installed? How can I test? Why is the config getting overriden?
Please help - and be aware that I have very little clue as to what the C
compiler setup is really doing so to be honest I need an idiots guide!
Any help greatly appreciated at this point...
Thanks
Tim
