[postgis-users] creating linestrings from points, complexish linestrings
Martin Davis mbdavis at refractions.net
Wed Apr 4 08:39:38 PDT 2007
First of all, don't you need some kind of ordering attribute on the
points?  Otherwise how would you determine the order the points occur in
the linestring?
Rhys Stewart wrote:
> Hi all,
> I have the following table:
> CREATE TABLE tmp.children
>  parish character varying(50),
>  pointnumber numeric(18),
>  parent character varying(254),
>  devicetype character varying(50),
>  coordfix geometry
> The table holds a parent-child relationship in columns pointnumber and
> parent.
> i.e., if a point has a parent the pointnumber  for that parent is in
> the parent field.
> The devicetype can either be Start, Inter or End. The only time a row
> has no parent is when its devicetype is start. There can be any number
> of inters.
> I would like to create one linestring encompassing an entire
> start-inter-end sequence and am having trouble wrapping my brain
> around it.
> Any suggestions?
> Thanks
> postgis-users mailing list
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
