[postgis-users] Problems with persisting/mapping org.postgis.PGbox3d via Hibernate
Jank, Klaus (SCR US)
klaus.jank at siemens.com
Wed Apr 4 15:00:55 PDT 2007
I am writing an application which Hibernate to map spatial objects like
geometry to postgis. That works very well with a Hibernate User Type for
Geometry types such as Point, etc.
Now, I am trying to adapt the org.postgis.hibernate.GeometryType
implementation to make it work for org.postgis.PGbox3d. However since
the BinaryParser and Writer doesn't support boxes I don't know which
type mapping I should use. For example just writing a string in the
nullSafeGet and nullSafeSet doesn't work. I always get a
SQLGrammerException.
Does anyone has similar problems or ideas. Thanks for help!!
Here is the detailed implementation of my Box3DType hibernate custom
type and the exception I get.
public class Box3DType implements UserType {
private static final int[] SQL_TYPES = { Types.OTHER };
public Object assemble(Serializable cached, Object owner)
throws HibernateException {
return cached;
public Object deepCopy(Object value) throws HibernateException {
return value;
public Serializable disassemble(Object value) throws HibernateException
return (Serializable) value;
public boolean equals(Object x, Object y) throws HibernateException {
if (x == y) {
return true;
} else if (x == null || y == null) {
return false;
} else {
return x.equals(y);
public int hashCode(Object arg0) throws HibernateException {
return 0;
public boolean isMutable() {
return false;
public Object nullSafeGet(ResultSet resultSet, String[] names, Object
owner)
throws HibernateException, SQLException {
PGbox3d result = null;
String box3d = resultSet.getString(names[0]);
if (box3d != null) {
result = new PGbox3d(box3d);
return result;
public void nullSafeSet(PreparedStatement statement, Object value, int
index)
if (value == null) {
statement.setString(index, null);
} else {
PGbox3d box = (PGbox3d) value;
statement.setString(index, box.getValue());
public Object replace(Object original, Object target, Object owner)
return original;
public Class returnedClass() {
return PGbox3d.class;
public int[] sqlTypes() {
return Box3DType.SQL_TYPES;
Exception Output:
javax.persistence.RollbackException: Error while commiting the
transaction
at org.hibernate.ejb.TransactionImpl.commit(TransactionImpl.java:63)
at
com.siemens.fsp.gmg.gisdata.PostGisDBAccessStandaloneTest.testCreateGisC
ollection(PostGisDBAccessStandaloneTest.java:494)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.jav
a:39)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessor
Impl.java:25)
at java.lang.reflect.Method.invoke(Method.java:585)
at junit.framework.TestCase.runTest(TestCase.java:154)
at junit.framework.TestCase.runBare(TestCase.java:127)
at junit.framework.TestResult$1.protect(TestResult.java:106)
at junit.framework.TestResult.runProtected(TestResult.java:124)
at junit.framework.TestResult.run(TestResult.java:109)
at junit.framework.TestCase.run(TestCase.java:118)
at junit.framework.TestSuite.runTest(TestSuite.java:208)
at junit.framework.TestSuite.run(TestSuite.java:203)
at
org.eclipse.jdt.internal.junit.runner.junit3.JUnit3TestReference.run(JUn
it3TestReference.java:128)
at
org.eclipse.jdt.internal.junit.runner.TestExecution.run(TestExecution.ja
va:38)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTe
stRunner.java:460)
at
stRunner.java:673)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRun
ner.java:386)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main(RemoteTestRu
nner.java:196)
Caused by: org.hibernate.exception.SQLGrammarException: Could not
execute JDBC batch update
at
org.hibernate.exception.SQLStateConverter.convert(SQLStateConverter.java
:67)
at
org.hibernate.exception.JDBCExceptionHelper.convert(JDBCExceptionHelper.
java:43)
at
org.hibernate.jdbc.AbstractBatcher.executeBatch(AbstractBatcher.java:249
at
org.hibernate.jdbc.AbstractBatcher.prepareStatement(AbstractBatcher.java
:92)
at
:87)
at
org.hibernate.jdbc.AbstractBatcher.prepareBatchStatement(AbstractBatcher
.java:218)
at
org.hibernate.persister.entity.AbstractEntityPersister.insert(AbstractEn
tityPersister.java:2159)
at
tityPersister.java:2595)
at
org.hibernate.action.EntityInsertAction.execute(EntityInsertAction.java:
51)
at org.hibernate.engine.ActionQueue.execute(ActionQueue.java:248)
at org.hibernate.engine.ActionQueue.executeActions(ActionQueue.java:232)
at org.hibernate.engine.ActionQueue.executeActions(ActionQueue.java:139)
at
org.hibernate.event.def.AbstractFlushingEventListener.performExecutions(
AbstractFlushingEventListener.java:298)
at
org.hibernate.event.def.DefaultFlushEventListener.onFlush(DefaultFlushEv
entListener.java:27)
at org.hibernate.impl.SessionImpl.flush(SessionImpl.java:1000)
at org.hibernate.impl.SessionImpl.managedFlush(SessionImpl.java:338)
at
org.hibernate.transaction.JDBCTransaction.commit(JDBCTransaction.java:10
6)
at org.hibernate.ejb.TransactionImpl.commit(TransactionImpl.java:53)
... 19 more
Caused by: java.sql.BatchUpdateException: Batch entry 0 insert into box
(dataStatus, importLocalityMO, importSRID, box, importedBox, id) values
(123, TestImportMOBox, 32632, "BOX3D(101 102,203 204)", "BOX3D(101
102,203 204)", 01c98a7a11be89d90111be89e9620010) was aborted. Call
getNextException to see the cause.
at
org.postgresql.jdbc2.AbstractJdbc2Statement$BatchResultHandler.handleErr
or(AbstractJdbc2Statement.java:2497)
at
org.postgresql.core.v3.QueryExecutorImpl$1.handleError(QueryExecutorImpl
.java:399)
at
org.postgresql.core.v3.QueryExecutorImpl.processResults(QueryExecutorImp
l.java:1298)
at
org.postgresql.core.v3.QueryExecutorImpl.execute(QueryExecutorImpl.java:
347)
at
org.postgresql.jdbc2.AbstractJdbc2Statement.executeBatch(AbstractJdbc2St
atement.java:2559)
at
org.hibernate.jdbc.BatchingBatcher.doExecuteBatch(BatchingBatcher.java:4
8)
at
org.hibernate.jdbc.AbstractBatcher.executeBatch(AbstractBatcher.java:242
... 34 more
SIEMENS
Klaus Jank
Technical Liaison Manager Java
Siemens Corporate Research, Inc.
Software Engineering
755 College Road East
Princeton, NJ 08540
USA
klaus.jank <mailto:klaus.jank at siemens.com> @siemens.com
+1 (609) 734 3581 (phone)
+1 (609) 734-6565 (fax)
+1 (650) 704 8746 (mobile)
https://java.siemens.com/jtf/ (intranet)
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070404/565b7986/attachment.html>
