[postgis-users] Checking the point location against a line
Pedro Doria Meunier
pdoria at netmadeira.com
Fri Apr 6 21:18:59 PDT 2007
Hey G. Lu,
This is best accomplished programmatically (at least from where I stand :])
LatLon is your friend here
. (coords are returned as (+-)99.999999)
To determine if the point is above the line Ive already shown you
About up, down, left, right
You can extract a single point from the line with pointn(geometry,1)
(points start at 1 in line segs)
(should you want to debugvisually confirm cordsuse :
astext(pointn(geometry,1))
The flux for it is loosely this:
If (pointLon> Linepoint[1].Lon) then RIGHT;
Elseif (pointLon<Linepoint[1]Lon) then LEFT;
Elseif (pointLat>Linepoint[1].Lat) then UP;
Elseif (pointLat<Linepoint[1].Lat) then DOWN;
Else FREAKISH_CASE!:]
<Gurus>
Theres probably a more elegant way to do this in PL/SQL
</Gurus>
HTH,
Pedro.
From: ray at codemeit.com [mailto:ray at codemeit.com] On Behalf Of Ray G. Lu
Sent: sábado, 7 de Abril de 2007 3:05
To: Pedro Doria Meunier; postgis-users at postgis.refractions.net
Subject: Re: [postgis-users] Checking the point location against a line
Hello Pedro ,
Thanks for your reply,
What I meant was how to determine P(x0,y0)
is above the line or LEFT side of the line,
or P(x2,y2) is below the line or RIGHT side of the line.
P(x0,y0) Above the line
This is line
-------------------------------o-------------------------------------
P(x1,y1) On the line
P(x2,y2) Below the line
Thanks,
G. LU
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070407/ec20368b/attachment.html>
