[postgis-users] RE: Select Point or PolyGon Polyline in Box
anhtin
anhtin at gmail.com
Tue Apr 10 21:32:03 PDT 2007
thanks
How is Select if it is Point ?????
Obe, Regina DND\MIS wrote:
> Assuming your box is in the same srid as your points. It would be
> something like
> SELECT *
> FROM pointdemo
> WHERE the_point && setsrid('BOX(295149 2315499, 465992
> 2163790)'::box2d, -1)
> Note - above I am assuming your point geometry is called the_point and
> your SRID is -1
> If the srid of your point geometry is not -1 then change -1 to what it
> should be.
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
> anhtin
> Sent: Tuesday, April 10, 2007 6:18 AM
> To: postgis-users at postgis.refractions.net
> Subject: [postgis-users] Select Point or PolyGon Polyline in Box
> hi all
> i have question to postgis
> i have table Pointdemo
> I want select all point in my Box("Rectangle") on PostGis
> my box is corrdinate
> ex: full extend is:Box(110638 2587481, 903350 1972446) ---> xmin ymin,
> xmax
> ymax
> i want select point in Box(295149 2315499, 465992 2163790) ---> xmin
> ymin,
> xmax ymax
> How will i do that ?????
> http://www.nabble.com/Select-Point-or-PolyGon-Polyline-in-Box-tf3552167.
> html#a9916986
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
> The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure
> pursuant to Massachusetts law. It is intended
> solely for the addressee. If you received this in error, please
> contact the sender and delete the material from any computer.
View this message in context: http://www.nabble.com/Select-Point-or-PolyGon-Polyline-in-Box-tf3552167.html#a9933066
