[postgis-users] && BBOX Question
Mark Cave-Ayland
mark.cave-ayland at ilande.co.uk
Wed Apr 11 00:01:31 PDT 2007
On Tue, 2007-04-10 at 23:33 -0700, Dylan Lorimer wrote:
> Hi,
> I'm curious if anyone can quickly see what I may be doing wrong here.
> I'm trying to restrict a query such that the geometry falls within a
> specified BBOX. Basic PostGIS stuff....right?
> However, for the following query, I'm not expecting to get any
> results, as the bbox specified has no points lying within it. And yet
> I get the result below.
> BOX3D is specified as (xmin ymin, xmax ymax) right?
> So here's the query:
> SELECT AsText(the_geom) AS the_geom, FACILITY_N, OBJECTID,
> FACILITY_I, DEPTNAME FROM poi_2 WHERE lower(FACILITY_N) LIKE '%lafa%'
> OR lower(OBJECTID) LIKE '%lafa%' OR lower(FACILITY_I) LIKE '%lafa%' OR
> lower(DEPTNAME) LIKE '%lafa%' AND the_geom && SetSRID('BOX3D(- 121.00
> 38.000, -119.00 40.00)'::box3d,4326);
> the_geom | facility_n | objectid |
> facility_i | deptname
> POINT(-122.497 37.7771) | LAFAYETTE SCHOOL (ELEM.) | 1969 |
> 0000003158 | SF Unified School District (SFUSD)
> Here's the table description:
> \d poi_2;
> Table "public.poi_2"
> Column | Type | Modifiers
> facility_n | character varying |
> objectid | character varying |
> facility_i | character varying |
> deptname | character varying |
> the_geom | geometry |
> Indexes:
> "deptname_gepoi_2_idx" btree (lower(deptname::text))
> "facility_i_gepoi_2_idx" btree (lower(facility_i::text))
> "facility_n_gepoi_2_idx" btree (lower(facility_n::text))
> "objectid_gepoi_2_idx" btree (lower(objectid::text))
> "the_geom_gepoi_2_idx" gist (the_geom)
> Check constraints:
> "enforce_dims_the_geom" CHECK (ndims(the_geom) = 2)
> "enforce_geotype_the_geom" CHECK (geometrytype(the_geom) =
> 'POINT'::text OR the_geom IS NULL)
> "enforce_srid_the_geom" CHECK (srid(the_geom) = 4326)
> Any ideas?
> Cheers,
> Dylan
Hi Dylan,
I think that what you're seeing here is a result of operator precedence
- see the table in the PostgreSQL documentation here:
http://www.postgresql.org/docs/8.2/interactive/sql-syntax-lexical.html#SQL-PRECEDENCE.
AFAICT your query is actually being parsed like this (brackets added for
emphasis):
SELECT AsText(the_geom) AS the_geom, FACILITY_N, OBJECTID, FACILITY_I,
DEPTNAME FROM poi_2
OR
(lower(DEPTNAME) LIKE '%lafa%' AND the_geom && SetSRID('BOX3D(-121.00
38.000, -119.00 40.00)'::box3d,4326));
Hence your single row is being returned as a match on "lower(FACILITY_N)
LIKE '%lafa%'". I think that what you are probably looking for is this
(again note the position of the extra brackets):
DEPTNAME FROM poi_2
WHERE
(lower(FACILITY_N) LIKE '%lafa%' OR lower(OBJECTID) LIKE '%lafa%' OR
lower(FACILITY_I) LIKE '%lafa%' OR lower(DEPTNAME) LIKE '%lafa%')
AND
the_geom && SetSRID('BOX3D(- 121.00 38.000, -119.00
This should cause your row to match only if *any* of the fields contain
a reference to "lafa" AND the geometry lies within the specified
bounding box.
Kind regards,
Mark.
