[postgis-users] Convert Corrdinate Pixel to Corrdinate Spatial
ValiSystem vali.system at free.fr
Wed Apr 11 03:28:31 PDT 2007
On 11 avr. 07, at 12:14, ValiSystem wrote:
> On 11 avr. 07, at 05:54, anhtin wrote:
>> hi all
>> I have Point (194, 569) is corrdinate pixel i want convert to
>> corrdinate
>> spatial on postgis
>> How can i do that ????
>> View this message in context: http://www.nabble.com/Convert-
>> Corrdinate-Pixel-to-Corrdinate-Spatial-tf3557178.html#a9932812
>> Sent from the PostGIS - User mailing list archive at Nabble.com.
> Hi,
> This is more a gdal thing, but there is no simple tool to do that.
> But what you can do if you want to keep most of the work in
> postgis, is to manually convert your pixel coordinates in your
> image spatial coordinates system, and then convert it to your final
> coordinates system (Lat Lon for example) inside postgis using
> Transform().
> Assuming that your image projection use a orthogonal coordinates
> system (it should), converting your pixel coordinates  xp, yp in
> your image spatial coordinates system is easy, for an image that
> have x1,y1 for bottom left corner and x2,y2 for top left corner
> (get it with gdalinfo) you just have to do :
> x = xp/width * (x2 - x1) + x1
> y = yp/height * (y2 - y1) + y1
> then you can do
> SELECT Transform(AsEWKT("SRID=<IMAGE_SRID>;POINT(<x>, <y>)"),
> <TARGET_SRID>);
> to let postgis calculate the complicated thing.
> But your message wasn't very clear, your may just need the first
> part of my response :)
Wooops, some typos and mistakes (damn, bad habit to avoid verify what
i post :) )
The correct query is :
SELECT Transform('SRID=<IMAGE_SRID>;POINT(<x> <y>)',  <TARGET_SRID>);
(no comma for the WKT point coordinates and and no need of  AsEWKT()
call )
