[postgis-users] Latitude and Longitude format in PostGIS
Giuseppe Molinario g.molinario at gmail.com
Wed Apr 11 12:04:31 PDT 2007
Hi Mark,
Yes, that helps. I'll see if i missed the proj4 installation along the way,
or if, more probably i am simply feeding PostGIS lat/long data that is not
in decimal degrees.
I'll let you know if it doesn't work.
Thanks,
Giuseppe
On 4/11/07, Mark Cave-Ayland <mark.cave-ayland at ilande.co.uk> wrote:
> On Wed, 2007-04-11 at 13:58 +0200, Giuseppe Molinario wrote:
> > Hi everyone,
> Hi Guiseppe,
> > I have a question regarding the creation in PostGIS of a table that
> > contains information coming from a NMEA GPRMC text string. I get
> > Lat/long coordinates which are then put into their respective columns.
> > A geometry field is then created using the SRID # 4326 (WGS84 Datum -
> > Geographic).
> > 1. What format of Lat/long coordinates does PostGIS accept? GPRMC has
> > the coordinate in this format: ddmm.mmmmm.
> PostGIS accepts coordinates in decimal degrees.
> > 2. How do I project the points into WGS84UTM33N? My final goal is to
> > overlay these points as a PostGIS layer on a webmap (Mapserver based)
> > over other data I have which is in that projection.
> The transform() function should be able to do what you need here if you
> use a version of PostGIS that has been compiled with the PROJ.4
> reprojection library.
> > 3. Do you know if Mapserver will re-project on the fly in my case?
> > ever? or do I have to take care of this in PostGIS?
> Yes. Mapserver can also reproject layers on-the-fly using PROJ.4. There
> are plenty of examples on the Mapserver website at
> http://mapserver.gis.umn.edu.
> HTH,
> Mark.
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070411/3d047852/attachment.html>
