[postgis-users] RE: RE: Select Point or PolyGon Polyline in Box
    anhtin
    anhtin at gmail.com
    Wed Apr 11 20:40:28 PDT 2007
Thanks very much  so support for me
if  i have that point i want select this point be in Polygon
ex: i have table Polygon is province.  i want select point(295054 849444) be
in Polygon  ????
and or be in polyline
can u show 2 way with polygon and polyline
thanks befor :)
Obe, Regina     DND\MIS wrote:
> Don't quite get what you are asking?  Are you trying to compare if 2
> points are the same or if a point is within x distance of another point?
> or something entirely different?
> If you wanted to select all points within x distance of your reference
> point , then it would be (again replace -1 with the correct SRID and
> distance is always measured in the units of your spatial reference
> system)
> SELECT *
> FROM pointdemo
> WHERE the_point && Expand(GeomFromText('POINT(295149 2315499)', -1), 10)
> AND
> 	distance(the_point,GeomFromText('POINT(295149 2315499)', -1)) <=
> 10
> If you wanted to know if 2 points are the same then it would be
> SELECT *
> FROM pointdemo
> WHERE the_point ~= GeomFromText('POINT(295149 2315499)', -1)
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
> anhtin
> Sent: Wednesday, April 11, 2007 12:32 AM
> To: postgis-users at postgis.refractions.net
> Subject: [postgis-users] RE: Select Point or PolyGon Polyline in Box
> thanks
> How is Select if it is Point ?????
>> Assuming your box is in the same srid as your points.  It would be
>> something like
>> SELECT *
>> FROM pointdemo
>> WHERE  the_point && setsrid('BOX(295149 2315499, 465992
>> 2163790)'::box2d, -1)
>> Note - above I am assuming your point geometry is called the_point and
>> your SRID is -1
>> If the srid of your point geometry is not -1 then change  -1 to what
> it
>> should be.
>> anhtin
>> Sent: Tuesday, April 10, 2007 6:18 AM
>> Subject: [postgis-users] Select Point or PolyGon Polyline in Box
>> hi all
>> i have question to postgis
>> i have table Pointdemo
>> I want select all point in my Box("Rectangle") on PostGis
>> my box is corrdinate
>> ex: full extend is:Box(110638 2587481, 903350 1972446) ---> xmin ymin,
>> xmax
>> ymax
>> i want select point in Box(295149 2315499, 465992 2163790)  ---> xmin
>> ymin,
>> xmax ymax
>> How will i do that ?????
>> View this message in context:
> http://www.nabble.com/Select-Point-or-PolyGon-Polyline-in-Box-tf3552167.
>> html#a9916986
>> Sent from the PostGIS - User mailing list archive at Nabble.com.
>> postgis-users mailing list
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> The substance of this message, including any attachments, may be
>> confidential, legally privileged and/or exempt from disclosure
>> pursuant to Massachusetts law. It is intended
>> solely for the addressee. If you received this in error, please
>> contact the sender and delete the material from any computer.
> html#a9933066
View this message in context: http://www.nabble.com/Select-Point-or-PolyGon-Polyline-in-Box-tf3552167.html#a9952489
