[postgis-users] RE: RE: PostGIS - hibernate (new postgis.jar)
rabbiaqaswar
rabbiaqaswar at yahoo.com
Wed Apr 11 22:38:16 PDT 2007
Hello
Thanks for your reply. I found this
http://svn.refractions.net/postgis/trunk/java/ejb3/ svn link from your
earlier posts in this topic, which has that ejb3spatial.pdf file. Can you
please tell me which svn link has the latest information.
Many Thanks
Norman Barker-3 wrote:
> Hi,
> There has been a lot of activity with the hibernate postgis driver, just
> everyone thinks it isn't of interest to the list and mail me directly!!
> (I have no problem with this).
> The major update is the spatial dialect for ejb3 (hibernate) allowing
> you to make spatial queries in object space, e.g. select obj from
> mytable where spatial.within(obj.box, ...)
> The code is in SVN, but I don't believe it is in postgis.jar, it is
> heavily dependent on the JDBC driver and hibernate for its
> functionality.
> Thanks,
> Norman
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
> rabbiaqaswar
> Sent: 10 April 2007 13:29
> To: postgis-users at postgis.refractions.net
> Subject: [postgis-users] RE: PostGIS - hibernate (new postgis.jar)
> Thankyou all for the support.
> I am using EJB3 with PostgreSQL & JBoss. Read through the tutorial on
> svn
> by Norman Barker. I compiled the GeometryType java file in
> org.postgis.hibernate and included the org.postgis.hibernate package in
> my
> classpath and the whole thing worked.
> Since the last post on this forum was in November 2006, i wanted to know
> that is there any change in the method to handle gis data from
> postgresql
> tables using ejb3 architecture? Is the GeometryType class by Norman
> included
> in the latest release of postgis.jar or should it be included seperately
> like i mentioned above?
> Thanks again
>> I think I missed the start of this thread (and I can't find it in the
>> archives), can you summarize the problem, and the server you are
> using?
>> The GeometryUserType class doesn't do very much but call out to the
>> utility functions provided in the postgis jar, so it does sound like a
>> classpath issue.
>> If you can send me a summary I will try to recreate the problem. (I
>> have both tomcat and jboss set up here).
>> If the attachment is large please send it to
> norman.barker<at>gmail.com
>> Thanks,
>> Norman
> Jan
>> Syryn
>> Sent: 27 November 2006 16:39
>> To: 'PostGIS Users Discussion'
>> Subject: RE: [postgis-users] PostGIS - hibernate (new postgis.jar)
>> Warning: Your file, postgis2.jar, contains more than 32 files after
>> decompression and cannot be scanned.
>> Hi Markus,
>> The thing I did to be able to continue is I have created a
>> postgis_addon.jar
>> lib that contained only new stuff like BinaryWriter.class and
>> GeometryUserType.
>> And that works. It does not solve the problem, though I can use the
>> latest
>> version of postgis.
>> I tried to use the tip I found in my previous posting by changing the
>> name
>> of the postgresql-jdbc.jar drvier to pg-jdbc.jar driver with my new
>> build
>> postgis2.jar (version 1.1.5)
>> I did not help.
>> If I remove the 2 stub files (PGConnection and Connection) from
>> postgis2.jar
>> : same result.
>> It stucks again on "No suitable driver".
>> If I replace the postgis2.jar by postgis.jar(1.1.0) and
>> postgis_addon.jar by
>> changing the settings on the classpath, everything works again.
>> So, I assume there is a thing in postgis2.jar.
>> And to create my postgis2.jar, I made a separate project in Eclipse,
>> created
>> a jar file of almost all java files(exl examples). This should do it,
> no
>> Anyway, I included my postgis2.jar so maybe one can replace his one
> with
>> mine and see what that does.
>> Or maybe one sees what I am doing wrong elsewhere...
>> TIA,
>> Jan
>> Markus
>> Schaber
>> Sent: samedi 25 novembre 2006 10:16
>> To: PostGIS Users Discussion
>> Subject: Re: [postgis-users] RE: RE: RE: PostGIS - hibernate - EJB3
>> Hi,
>> Norman Barker wrote:
>>> 2. In the thread here, people are using:
>>> <driver-class>org.postgis.DriverWrapper</driver-class>
>>> When I do the same, I get a "No suitable driver" exception.
>>> 3. I wanted to use the GeometryType that is packed in PostGIS 1.1.5.
>>> After generating the new JAR and replacing the old one by this one, I
>>> start getting new exceptions:
>>> The class org.postgis.PGbox3d does not implement
>>> org.postgresql.util.PGobject.
>> Those 2 things look like a classpath/classloader problem.
>> You have to make sure that the postgis.jar and the postgresql-jdbc.jar
>> are
>> available via the same classloader (and that you don't have two
>> incarnations
>> of them in your classpath)
>> HTH,
>> Markus
>> Markus Schaber | Logical Tracking&Tracing International AG
>> Dipl. Inf. | Software Development GIS
>> Fight against software patents in Europe! www.ffii.org
>> www.nosoftwarepatents.org
>> postgis-users mailing list
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> http://www.nabble.com/PostGIS---hibernate---EJB3-tf2064211.html#a9926716
> Sent from the PostGIS - User mailing list archive at Nabble.com.
View this message in context: http://www.nabble.com/PostGIS---hibernate---EJB3-tf2064211.html#a9953356
