[postgis-users] RE: pgsql2shp
Brent Wood
pcreso at pcreso.com
Thu Apr 12 21:47:55 PDT 2007
--- anhtin <anhtin at gmail.com> wrote:
> thanks very much all support to me
> How can i customize the Query
> Ex: i have Box (295149 2315499, 465992 2163790)
> can I export this box ???
I'm not sure what you mean by export, but if you want to use this box in a
query, try something like:
pgsql2shp -f myshp -h myserver -u apguser -P apgpassword mygisdb
"select * from province WHERE id IN(1,2,3,4,67,34)
and geom && SetSRID('BOX3D(295149 2315499, 465992 2163790)'::box3d,-1)
See the docs at http://postgis.refractions.net/docs/ch04.html#id2640015
Cheers,
Brent Wood
> > "select * from province WHERE id IN(1,2,3,4,67,34,23,22)"
> > Note the myshp is the shapefile name without the suffix
> > So if you wanted to output province.shp and province.dbf you would just
> > type in province for myshp
> > Hope that helps,
> > Regina
> > -----Original Message-----
> > From: postgis-users-bounces at postgis.refractions.net
> > [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
> > anhtin
> > Sent: Thursday, April 12, 2007 5:34 AM
> > To: postgis-users at postgis.refractions.net
> > Subject: [postgis-users] pgsql2shp
> > Hi all
> > I am developing application Web use Mapserver and Database Postgis
> > I want Export Data Corrdinate in Post Gis to shapfile. But Export with
> > condition
> > ex: select * from Province where id in '1,2,3,4,67,34,23,22'
> > How can i do that ???
> > View this message in context:
> > http://www.nabble.com/pgsql2shp-tf3564424.html#a9956047
> > Sent from the PostGIS - User mailing list archive at Nabble.com.
> > postgis-users mailing list
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
> > The substance of this message, including any attachments, may be
> > confidential, legally privileged and/or exempt from disclosure
> > pursuant to Massachusetts law. It is intended
> > solely for the addressee. If you received this in error, please
> > contact the sender and delete the material from any computer.
> http://www.nabble.com/pgsql2shp-tf3564424.html#a9971889
