[postgis-users] subqueries in update?
Marc Weber marco-oweber at gmx.de
Fri Apr 13 03:19:59 PDT 2007
Beeing a total noob I wonder wether I can use suqueries such like
update haueser set inside=contains(geomunion( (SELECT the_geom from shape) ),the_geom);
to set a property of each row indicating that the polygon is inside the union of all polygons of table shape.
Reading posgres documentation I only could find subqieries in the Where or
SELECT ... part of a query.
If not how would you accomplish this task?
Marc
