[postgis-users] RE: Select Point or PolyGon Polyline in Box
anhtin
anhtin at gmail.com
Fri Apr 13 02:38:26 PDT 2007
anhtin wrote:
> thanks reply
> but have some problem
> i think the command doen't exact. because when i get box on the map have a
> porvince but when i run in post have 2 result ???
> SELECT gid, name, code, ma FROM province
> WHERE the_geom && setsrid('BOX(472825.36726087
> 2140555.40234783,516561.185 2107753.53904348)'::box2d, 42102)
> when u show me ex: with point is excatly
> SELECT *
> FROM province WHERE GeomFromText('POINT(472825.36726087
> 2140555.40234783)', 42102) && the_geom
> AND distance(the_geom, GeomFromText('POINT(472825.36726087
> 2140555.40234783)', 42102)) = 0
> but i try same with Box is error
> can u show me???
> Obe, Regina DND\MIS wrote:
>> Assuming your box is in the same srid as your points. It would be
>> something like
>> SELECT *
>> FROM pointdemo
>> WHERE the_point && setsrid('BOX(295149 2315499, 465992
>> 2163790)'::box2d, -1)
>> Note - above I am assuming your point geometry is called the_point and
>> your SRID is -1
>> If the srid of your point geometry is not -1 then change -1 to what it
>> should be.
>> -----Original Message-----
>> From: postgis-users-bounces at postgis.refractions.net
>> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
>> anhtin
>> Sent: Tuesday, April 10, 2007 6:18 AM
>> To: postgis-users at postgis.refractions.net
>> Subject: [postgis-users] Select Point or PolyGon Polyline in Box
>> hi all
>> i have question to postgis
>> i have table Pointdemo
>> I want select all point in my Box("Rectangle") on PostGis
>> my box is corrdinate
>> ex: full extend is:Box(110638 2587481, 903350 1972446) ---> xmin ymin,
>> xmax
>> ymax
>> i want select point in Box(295149 2315499, 465992 2163790) ---> xmin
>> ymin,
>> xmax ymax
>> How will i do that ?????
>> View this message in context:
>> http://www.nabble.com/Select-Point-or-PolyGon-Polyline-in-Box-tf3552167.
>> html#a9916986
>> Sent from the PostGIS - User mailing list archive at Nabble.com.
>> postgis-users mailing list
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> The substance of this message, including any attachments, may be
>> confidential, legally privileged and/or exempt from disclosure
>> pursuant to Massachusetts law. It is intended
>> solely for the addressee. If you received this in error, please
>> contact the sender and delete the material from any computer.
View this message in context: http://www.nabble.com/Select-Point-or-PolyGon-Polyline-in-Box-tf3552167.html#a9975872
