[postgis-users] Problems with PHP and PostgreSQL/PostGIS
Gerald Baumgartner baumgartner.gerald at gmail.com
Fri Apr 13 06:15:58 PDT 2007
Thanks All!
Now it works!
2007/4/13, Mark Cave-Ayland <mark.cave-ayland at ilande.co.uk>:
> On Fri, 2007-04-13 at 14:55 +0200, Gerald Baumgartner wrote:
> > I have renamed the tablename, but now there are other errors:
> > Warning: pg_query() [function.pg-query]: Query failed: ERROR: column
> > "date_start_fahrt" is of type date but expression is of type integer
> > at character 36 HINT: You will need to rewrite or cast the expression.
> > in C:\ms4w\Apache\htdocs\GpsDaten\GPS_Daten_einlesen.php on line 103
> > Warning: pg_query() [function.pg-query]: Query failed: ERROR: invalid
> > input syntax for type numeric: "" in C:\ms4w\Apache\htdocs\GpsDaten
> > \GPS_Daten_einlesen.php on line 112
> > php Code:
> >     $timestamp=time();
> >     $datum=date("d/m/y",$timestamp);
> >     if($z_eintraege==2)
> >        $sql_befehl="INSERT INTO
> > fahrtenbuchtabelle(fid,date_start_fahrt,date_insert,strecke) VALUES
> > ($z_eintraege,$datum,$datum,GeometryFromText('LINESTRING($breitengrad1
> > $laengengrad1, $breitengrad $laengengrad)',4326))";
> >        $res=pg_query($connection,$sql_befehl);
> >        $sql_befehl_select="SELECT max(FID) as fid from
> > fahrtenbuchtabelle";
> >        $res_fid=pg_query($connection,$sql_befehl_select);
> >        $fahrtnummer=pg_result($res_fid,"fid");
> >     if($z_eintraege>2)
> >       $sql_befehl_append="UPDATE fahrtenbuchtabelle SET
> > strecke=AddPoint(strecke,GeomFromText('POINT($breitengrad
> > $laengengrad)',4326)) where fid='$fahrtnummer'";
> >       $result=pg_query($connection,$sql_befehl_append);
> > Gerald
> Hi Gerald,
> As Regina points out, you need to quote the date field with apostrophes
> in the VALUES clause since the date needs to be passed in as a string.
> Also a word of warning: you should look very carefully at your code; by
> creating strings using "s and including variables as $var, it is
> extremely likely that your code is vulnerable to an SQL injection attack
> if register_globals is enabled and your variables are being passed in as
> CGI parameters to your PHP page.
> Kind regards,
> Mark.
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070413/10b399f0/attachment.html>
