[postgis-users] Problems with PHP and PostgreSQL/PostGIS
Gerald Baumgartner baumgartner.gerald at gmail.com
Fri Apr 13 06:21:40 PDT 2007
where should I change an entry in geometry_columns table? I can't see there
anything about the table I had changed.
Gerald
2007/4/13, Obe, Regina <robe.dnd at cityofboston.gov>:
>  Yap that was what I was saying that I thought you might have problems
> with your date.  Sorry didn't notice the $datum declaration you had at the
> top.
> I think the way you format the date has to match with your PostGreSQL date
> style or I think also the ISO date standard which is YYYY-MM-DD
> and as I mentioned you need to quote your date field in your sql so your
> sql should be
> INSERT INTO fahrtenbuchtabelle(fid,date_start_fahrt,date_insert,strecke)
> VALUES
> ($z_eintraege,'$datum','$datum',GeometryFromText('LINESTRING($breitengrad1
> $laengengrad1, $breitengrad $laengengrad)',4326))";
> I also tend to go with the ISO date standard - less headache since it is
> not ambiguous like the other formats.  So your $datum would be declared
> $datum = date("Y-m-d", $timestamp);
> Also since you renamed your table, make sure to change the entry in
> geometry_columns table if it is not correct otherwise you may run into
> issues displaying the data.
> Hope that helps,
> Regina
> *From:* postgis-users-bounces at postgis.refractions.net [mailto:
> postgis-users-bounces at postgis.refractions.net] *On Behalf Of *Gerald
> Baumgartner
> *Sent:* Friday, April 13, 2007 8:55 AM
> *To:* PostGIS Users Discussion
> *Subject:* Re: [postgis-users] Problems with PHP and PostgreSQL/PostGIS
> I have renamed the tablename, but now there are other errors:
> *Warning*: pg_query() [function.pg-query<http://localhost/GpsDaten/function.pg-query>]:
> Query failed: ERROR: column "date_start_fahrt" is of type date but
> expression is of type integer at character 36 HINT: You will need to rewrite
> or cast the expression. in *
> C:\ms4w\Apache\htdocs\GpsDaten\GPS_Daten_einlesen.php* on line *103*
> Query failed: ERROR: invalid input syntax for type numeric: "" in *C:\ms4w\Apache\htdocs\GpsDaten\GPS_Daten_einlesen.php
> *on line *112*
> php Code:
>     $timestamp=time();
>     $datum=date("d/m/y",$timestamp);
>     if($z_eintraege==2)
>        $sql_befehl="INSERT INTO
> fahrtenbuchtabelle(fid,date_start_fahrt,date_insert,strecke) VALUES
> ($z_eintraege,$datum,$datum,GeometryFromText('LINESTRING($breitengrad1
>        $res=pg_query($connection,$sql_befehl);
>        $sql_befehl_select="SELECT max(FID) as fid from
> fahrtenbuchtabelle";
>        $res_fid=pg_query($connection,$sql_befehl_select);
>        $fahrtnummer=pg_result($res_fid,"fid");
>     if($z_eintraege>2)
>       $sql_befehl_append="UPDATE fahrtenbuchtabelle SET
> strecke=AddPoint(strecke,GeomFromText('POINT($breitengrad
> $laengengrad)',4326)) where fid='$fahrtnummer'";
>       $result=pg_query($connection,$sql_befehl_append);
> Gerald
> >  When you created your table it appears you created it as FahrtenbuchTabelle,
> > but in your PHP sql, you don't have the table name quoted, it will take what
> > you have and insert into a table called fahrtenbuchtabelle.  All table names
> > that are not quoted in sql will be lowercased when passed to the processor.
> > To minimize on headache, you really should rename your table in
> > PostgreSQL to fahrtenbuchtabelle.  Note that PostgreSQL table names are
> > case sensitive so FahrtenbuchTabelle  and fahrtenbuchtabelle are not the
> > same name.
> > Other possibly potential problem, I can't tell how you are passing in
> > your $datum date, but may need to be quoted.
> > Hope that helps,
> > Regina
> > Baumgartner
> > *Sent:* Friday, April 13, 2007 8:14 AM
> > *To:* postgis-users at postgis.refractions.net
> > *Subject:* [postgis-users] Problems with PHP and PostgreSQL/PostGIS
> >  Hi everyone!
> > I have created a table and now I want to put a GPS Logfile into this
> > table with a php file. But the php file doesn't do the inserts.
> > Please can someone help me!
> > The error message from the php file in firefox:
> > Query failed: ERROR: relation "fahrtenbuchtabelle" does not exist in *
> > Here are the commands in the php file*:
> >     if($z_eintraege==2)
> > FahrtenbuchTabelle(FID,Date_Start_Fahrt,Date_Insert,Strecke) VALUES
> > FahrtenbuchTabelle";
> >        $fahrtnummer=pg_query($connection,$sql_befehl_select);
> >     if($z_eintraege>2)
> >       $sql_befehl_append="UPDATE FahrtenbuchTabelle SET
> > Strecke=AddPoint(Strecke,GeomFromText('POINT($breitengrad
> > $laengengrad)',4326)) where FID='$fahrtnummer'";
> > And there is my table in postgresql/postgis:
> > CREATE TABLE "FahrtenbuchTabelle"
> >   "FID" numeric NOT NULL,
> >   "Date_Start_Fahrt" date NOT NULL,
> >   "Date_Insert" date NOT NULL,
> >   "Strecke" geometry,
> >   CONSTRAINT "FahrtID" PRIMARY KEY ("FID"),
> >   CONSTRAINT "enforce_dims_Strecke" CHECK (ndims("Strecke") = 2),
> >   CONSTRAINT "enforce_geotype_Strecke" CHECK (geometrytype("Strecke") =
> > 'LINESTRING'::text OR "Strecke" IS NULL),
> >   CONSTRAINT "enforce_srid_Strecke" CHECK (srid("Strecke") = 4326)
> > WITHOUT OIDS;
> > ALTER TABLE "FahrtenbuchTabelle" OWNER TO postgres;
> > Already thankful for any ideas.
> > The substance of this message, including any attachments, may be
> > confidential, legally privileged and/or exempt from disclosure
> > pursuant to Massachusetts law. It is intended solely for the
> > addressee. If you received this in error, please contact the sender
> > and delete the material from any computer.
> > postgis-users mailing list
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070413/1c2faf97/attachment.html>
