[postgis-users] Errors in geometry.
Jennehag Åke Ake.Jennehag at lm.se
Sun Apr 15 23:25:31 PDT 2007
Hi!
I'm using PostGIS 1.2.0 and PostgreSQL 8.2. Then I run a query like (I'm using the SQL client in PgAdmin III):
SELECT gid, asgml(geom) FROM bishkekeni WHERE NOT st_isvalid(geom)
I get a lot of text in the message window. It looks like this:
NOTICE:  Self-intersection
NOTICE:  Ring Self-intersection
I understand that this is the same errors that st_isvalid(geom) function is printing out. But I would like to have the text like 'Self-intersection' on each row for the objects that are not valid. Is there a function to print out these errors (must be I can see them!!)? How do I use it?
Something like this??
SELECT gid, asgml(geom), magicfunction(geom) FROM bishkekeni WHERE NOT st_isvalid(geom)
Regards
Åke Jennehag
National Land Survey of Sweden
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070416/eb87fc09/attachment.html>
