[postgis-users] transform problem
Mark Cave-Ayland
mark.cave-ayland at ilande.co.uk
Mon Apr 16 11:19:51 PDT 2007
On Mon, 2007-04-16 at 11:00 +0200, bange at argoss.nl wrote:
> I cannot get the Transform function working on Mac OSX. When I try
> something like
> select transform(geomfromtext('MULTIPOLYGON(((45340.81
> 387680.7,51892.99 387641.0, 52012.12 380810.8,45459.94
> 380850.5,45340.81 387680.7)))',28992),3395)
> I get a query that is running for some time, and the result is a ':'
> and 'lost connection to server'. Anybody got the same problem ?
> I am running postrgesql 8.1.5, postgis 1.1.6 proj 4.4.8.
> Thanks, Peter Bange
Hi Peter,
Are there any messages in the PostgreSQL server log? I get the following
output from psql here:
postgis=# select transform(geomfromtext('MULTIPOLYGON(((45340.81
postgis'# 387680.7,51892.99 387641.0, 52012.12 380810.8,45459.94
postgis'# 380850.5,45340.81 387680.7)))',28992),3395);
ERROR: AddToPROJ4SRSCache: Cannot find SRID (3395) in spatial_ref_sys
postgis=# select * from spatial_ref_sys where srid = 3395;
srid | auth_name | auth_srid | srtext | proj4text
(0 rows)
postgis=# select postgis_full_version();
POSTGIS="1.1.6" PROJ="Rel. 4.5.0, 22 Oct 2006" USE_STATS
(1 row)
postgis=# select version();
version
PostgreSQL 8.1.8 on i486-pc-linux-gnu, compiled by GCC gcc-4.0.gcc-opt
(GCC) 4.0.3 (Ubuntu 4.0.3-1ubuntu5)
(1 row)
Also, a good check would be to see if the reprojection works for any
other SRID values...
Kind regards,
Mark.
