[postgis-users] Extending Linestrings
Julio Galindo
juliogalindoq at gmail.com
Mon Apr 16 21:53:11 PDT 2007
Hi Leticia,
I create the following function for your problem, please test it carefully,
I only made two test (at the end):
CREATE OR REPLACE FUNCTION ExtendLine(eje_ geometry, bound_ geometry)
RETURNS geometry AS $$
-- version: alfa , by Julio A. Galindo, April 17, 2007:
DECLARE
b_ geometry = boundary(bound_);
dist float;
max_dist float = 0;
n_points int;
pto_1 geometry;
pto_2 geometry;
first_pto geometry;
last_pto geometry;
u_1 float;
u_2 float;
norm float;
result text = 'LINESTRING(';
BEGIN
IF GeometryType(eje_) NOT LIKE 'LINESTRING'
OR GeometryType(bound_) NOT LIKE 'POLYGON' THEN RETURN NULL; END IF;
-- First Search how far is the boundary: (worst case)
pto_1 := StartPoint(eje_);
pto_2 := EndPoint(eje_);
FOR i IN 0..NumPoints(b_)-1 LOOP
dist := distance(PointN(b_,i),pto_1);
IF dist > max_dist THEN max_dist := dist; END IF;
dist := distance(PointN(b_,i),pto_2);
END LOOP;
-- Now extent the linestring:
pto_2 := PointN(eje_,2);
u_1 := X(pto_2)-X(pto_1);
u_2 := Y(pto_2)-Y(pto_1);
norm := sqrt(u_1^2 + u_2^2);
first_pto := MakePoint(X(pto_1)-u_1/norm*dist,Y(pto_1)-u_2/norm*dist);
n_points := nPoints(eje_);
IF n_points > 2 THEN
pto_1 := PointN(eje_,n_points-1);
pto_2 := PointN(eje_,n_points);
END IF;
last_pto := MakePoint(X(pto_2)+u_1/norm*dist,Y(pto_2)+u_2/norm*dist);
result := result || X(first_pto) || ' ' || Y(first_pto) || ',';
FOR i IN 1..NumPoints(eje_) LOOP
result := result || X(PointN(eje_,i)) || ' ' || Y(PointN(eje_,i)) || ',';
END LOOP;
result := result || X(last_pto) || ' ' || Y(last_pto) || ')';
-- Find the final Linestring:
b_ := intersection(GeomFromText(result,SRID(eje_)),bound_);
RETURN b_;
END $$
LANGUAGE plpgsql
STABLE
RETURNS NULL ON NULL INPUT;
Test 1:
select asText(extendLine(geomFromText('LINESTRING(5 5, 12
12)',-1),GeomFromText('POLYGON((0 0,15 0,15 20,0 20,0 0))',-1)));
astext
LINESTRING(0 0,5 5,12 12,15 15)
The solution is good, because the line is at 45 degress
And the same function can work with a general linestring (many points):
select asText(extendLine(geomFromText('LINESTRING(5 5, 12 12, 13
astext
LINESTRING(0 0,5 5,12 12,13 12,15 12)
Let me know if you improve this simple function.
Regards,
Julio A. Galindo Q.
Topogen Ltda.
La Paz, Bolivia
On 4/16/07, Leticia <lgomez at itba.edu.ar> wrote:
> Hi community,
> I need to "extend" a linestring in another one. The new linestring must be
> obtained such as their new extremes are the intersection of it with a
> polygon that contains it. The original linestring is composed of only a
> linear segment.
> Is there a simple method to do this?
> I need the other one:
> The original linestring is not always vertical u horizontal.
> Thanks in advance,
> Leticia
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070417/3cee4788/attachment.html>
